(o == null ? "null" : (o instanceof Lang.String ? "String" : (o instanceof Lang.Object ? "Object" : "?"))) ...
Thanks!
I wanted to try a code block with the .txt RaceQs posted. I'd heard it should be working. RaceQs - what error were you getting when you tried to post?
function type_name(obj) {
if (obj instanceof…
I have used this code quite a bit in the past. It isn't extremely efficient, but it is very flexible.
//! Module for writing an object or object hierarchy as a pretty string.
//! Simple module for pretty-printing MonkeyC objects. All native types
//! are handled by default. User-defined types can implement the special
//! __repr__ method to return a string representation. If the behavior
//! for a type (native or user-defined) needs to be changed, a callback
//! can be registered to override. The most recently registered callback
//! will be used.
//! @example
//! function hexadecimal_number(obj) {
//! return Lang.format("0x$1$", [ obj.format("%x") ]);
//! function scientific_float(obj) {
//! return obj.format("%e");
//! function demo() {
//! var d = { 1 => 3.14159 };
//! // prints "{ 1: 3.14159f }"
//! pretty.dump(d);
//! // override the behavior for Number
//! pretty.register_type(Lang.Number, method(:hexadecimal_number));
//! // override the behavior for Float
//! pretty.register_type(Lang.Float, method(:scientific_float));
//! // prints "{ 0x1: 3.141590e+00 }"
//! pretty.dump(d);
module pretty {
using Toybox.Lang;
using Toybox.System;
//! Register a callback to pretty format an object of the given type.
//! @param [type] The type of an object to use the given callback function for
//! @param [callback] A Lang.Method that generates a string representation of a type
function register_type(type, callback) {
_type_map.add(new TypeMapEntry(type, callback));
//! Remove a callback registered to pretty format an object of the given type.
//! Remove the most recently registered callback for the given type. Has no
//! effect if no registered function is found. The default handlers for the
//! built-in types cannot be removed, but they can be overridden by adding
//! a new callback with `register_type`.
//! @param [type] The type to deregister
function deregister_type(type) {
var n = _type_map.size();
for (var i = n - 1; i >= 0; --i) {
if (_type_map[i].type == type) {
_type_map.remove(_type_map[i]);
return;
//! Convert an object to a pretty string representation.
//! Convert an object to a pretty string representation using
//! 1) the most recent callback registered with `register_type`
//! that has not been removed with `deregister_type`
//! 2) the default formatting for built-in types
//! 3) the format provided by a class member function __repr__.
//! @param [obj] The object to convert.
//! @return String A pretty string representation of the object.
//! @throws UnexpectedTypeException if an object type is not known.
function dumps(obj) {
return _dumps(obj);
//! Write the pretty representation of an object to output.
//! write the pretty representation of the given object as if
//! by calling to System.println(pretty.dumps(obj)).
//! @param [obj] The object to write.
function dump(obj) {
_dump(obj);
System.print("\n");
// everything below this line is an implementation detail
// do not access these things
var _type_map = [];
class TypeMapEntry
function initialize(type, callback) {
self.type = type;
self.callback = callback;
var type;
var callback;
// return a pretty representation of the given object
function _dumps(obj) {
var entry = _type_map[i];
if (obj instanceof entry.type) {
return entry.callback.invoke(obj);
// default behavior for built-in types
if (obj instanceof Lang.Boolean) {
return obj.toString();
else if (obj instanceof Lang.Char) {
return Lang.format("'$1$'", [ obj ]);
else if (obj instanceof Lang.Double) {
return Lang.format("$1$d", [ obj.format("%g") ]);
else if (obj instanceof Lang.Float) {
return Lang.format("$1$f", [ obj.format("%g") ]);
else if (obj instanceof Lang.Long) {
return Lang.format("$1$L", [ obj ]);
else if (obj instanceof Lang.Number) {
else if (obj instanceof Lang.String) {
return Lang.format("\"$1$\"", [ obj ]);
else if (obj instanceof Lang.Array) {
var n = obj.size();
if (n == 0) {
return "[]";
var r = "[ ";
r += _dumps(obj[0]);
for (var i = 1; i < n; ++i) {
r += ", ";
r += _dumps(obj[i]);
r += " ]";
return r;
else if (obj instanceof Lang.Dictionary) {
var n = obj.size();
if (n == 0) {
return "{}";
var k = obj.keys();
var v = obj.values();
var r = "{ ";
r += _dumps(k[0]);
r += ": ";
r += _dumps(v[0]);
r += ", ";
r += _dumps(k[i]);
r += ": ";
r += _dumps(v[i]);
r += " }";
return r;
else if (obj instanceof Lang.ByteArray) {
else if (obj == null) {
return "null";
// special behavior for user-defined types
else if (obj has :__repr__) {
return obj.__repr__();
// no idea what to do here
else {
throw new Lang.UnexpectedTypeException(Lang.format("Unknown type for '$1$'", [ obj ]), null, null);
// display a pretty representation of the given object
function _dump(obj) {
System.print(entry.callback.invoke(obj));
return;
System.print(obj.toString());
System.print(Lang.format("'$1$'", [ obj ]));
System.print(Lang.format("$1$d", [ obj.format("%g") ]));
System.print(Lang.format("$1$f", [ obj.format("%g") ]));
System.print(Lang.format("$1$L", [ obj ]));
System.print(Lang.format("\"$1$\"", [ obj ]));
var n = obj.size();
if (n == 0) {
System.print("[]");
return;
System.print("[ ");
_dump(obj[0]);
System.print(", ");
_dump(obj[i]);
System.print(" ]");
var n = obj.size();
if (n == 0) {
System.print("{}");
return;
var k = obj.keys();
System.print("{ ");
_dump(k[0]);
System.print(": ");
_dump(v[0]);
System.print(", ");
_dump(k[i]);
System.print(":");
_dump(v[i]);
System.print(" }");
System.print("null");
System.print(obj.__repr__());
else {
