Can you help me solve strange set/getProperties behaviour?
I cant figure it out, what can't I see?
function onStart()
mSettings = getProperty(SETTINGS);
if(null == mSettings)
mSettings = new [15];
mSetting[0] = Ui.LoadResource( etc...
// app code
function onStop()
setProperty(SETTINGS, mSettings);
saveProperties();
Run 1/ First run and it jumps in to load the resources. I can change the settings. The changes are reflected as they happen.
Run 2/ Next run and it loads without loading the resources. I can see all the changes I made on the first run. I make some new changes and they are reflected as they happen.
Run 3/ Next run and it loads without loading the resources, but I can't see the changes from run 2??????
Why can't I save my settings array when it is loaded with getProperty()?
  • I spent a good amount of time looking into this yesterday afternoon, and tracked down the root of the problem. While I was experimenting, I discovered that if I copy the values from the settings array into a new temp array and save that back to the object store, it would work fine.
    Thanks for your hard work. I think, we would all have been working for a very long time o deduce this...
