Connect IQ 2.3 beta - blue arrow on startup
I installed the 2.3 beta inside a new eclipse neon (.3) as advised. When opening existing projects I only get a blue arrow on the screen, nothing else. Generating a new project seems to work fine...
Environment:
* Windows 10 (64 bit)
* Eclipse Neon .3 (64 bit)
* Connect IQ 2.3 beta SDK
To reproduce an example of an existing project http://starttorun.info/download.php?id=13
this is how it looks like:
  • The blue triangle screen was recently added to the simulator to display something when an app is not running (you can now kill the app without killing the device). My initial thought was like Jim's, that your apps are crashing, but I'm not convinced that's the case. Let's try something and see what happens:
    • Start the simulator via Eclipse (it is not necessary to launch an app)
    • Open a CMD prompt
    • cd to your 2.3.0 beta SDK's bin directory
    • Now, issue the following commands (including the numbers in the square brackets):
      • shell
      • ciq
      • [1]openDevice fenix5 (or some other device that your app supports)
      • [2]startApp <the manifest ID of an app that has not worked, do not include dashes>
    Here's a breakdown of what we're doing:
    • The first command should print a series of messages similar to what it displayed in the Eclipse console, and you'll be placed at a ':>' prompt
    • The second command should report "[1]shellConnected"
    • The third command should start the specified device in the simulator, displaying the familiar blue triangle, and report back "[1]deviceStarted"
    • The fourth command should start the app that matches the specified manifest ID, and report back "[2]appStarted"
    If it helps to have a visual reference, here's my CMD window while executing these commands:
    In my screen capture, there are a couple of lines that begin with '[3]' after the app has started--these are println() statements from my app, so you won't necessarily see these, but you may see other output from your app at this point if it launches. However, if the app does not start, that at least gives us a little better idea what's happening.
    The first thing to check at this point is your windows %TEMP%\GARMIN\Apps directory to see whether the app's PRG file is getting copied there. This is PRG the sim actually runs, and it's placed in the temp directory by the Eclipse plug-in when you attempt to run an app. If it's not there, then you'll need to see if something is interfering with that temp directory. If it is there, but you're still not getting it to run, let me know and I'll see what the next steps are.
  • Attached the beta behaviour of the "Fat Burner" App
    As you can see the startapp doesn't do much (the prg file is not stored in %temp%/Garmin/Apps)
    When I generate a new Simple DataField and copy the source files in there (renamed the app to FatApp) it works.
    Could be due to the fact that I edited the manifest file of the Fatburner App... I tried tweaking the edited manifest of the Fat Burner App (based on the generated Fat app manifest) but can't make it work for the Fat Burner manfest id...
    (I deleted the bin directory and edited a source file to make sure it regenerates)
    I've also attached my edited versions of the fat and fat_burner apps. (the fat_burner one is the one that does not work for me)
    the manifest.xml.old was my original manifest.xml file before trying to fix it
  • The issue might be more basic, it seems that none of the projects that contain spaces generate a PRG file.
    Simple test:
    * Create a complex datafield named a b
    * Create a complex datafield named ab
    For me the first one does not create a PRG file in the temp folder, the second one does.
    Renaming the "Fat Burner" project to "FatBurner" makes it work.
  • This was a bug at some point in the past. I haven't attempted to verify, but if this is the behavior you're seeing, it looks like it may have resurfaced.
  • I can reproduce this. I'll file a report to have it fixed.
    I get the same blue triangle a lot with the current SDK if I don't close the Simulator program before relaunching my app or watchface. This didn't happen with 2.2.x. I'm also on Windows and using Eclipse.
