Fit Contributor
Hi,
just a question to the FitContributor: If I calculate the average values of an high-intensity period of an interval and write those values to the Fit file, does Garmin connect web make those values somehow visible or is it just a value in the Fit file?
  • Hi,
    I have tried another implementation of the fitcontributor: writing a string to the lap section. It's not shown on GC website. I tried monkeygraph and it showed me this:
    https://www.dropbox.com/s/rf74mjgxe8gqev2/monkeygraph.JPG?dl=0
    The json file in the iq-archive showed me this:
    {"datafields":[{"id":0,"chart-visible":false,"activity-visible":false,"lap-visible":true,"chart-title-key":null,"label-key":"HrLabel","unit-label-key":"HrUnit","sort-order":0,"precision":null,"fill-color":null}],"strings":{"default":{"HrLabel":"HR av, lap, pred","HrUnit":"bpm"}}}
    What am I doing wrong that the things are screwed up?
  • Hi again,
    I don't know, what I changed (IMHO nothing), but now the lap fitcontribution works partly: in Garmin connect mobile, the values are correctly depicted whereas (the same activity) shows in Garmin connect web just 0.
    https://www.dropbox.com/s/9f889kvebbwebmv/Garmin%20Connect%20Web.JPG?dl=0
    How can I debug that?
  • Did another run today, changed the implementation a bit (by setting first data right in the constructor), the same results. GC mobile shows the values, GC web shows just zero. Can someone help please? I would e. g. send the code if it would be necessary...
  • If the data appears in the .FIT file and works correctly in Garmin Connect Mobile, what makes you think it isn't just a bug in Garmin Connect that prevents the values from being displayed?
    Travis
  • I feel your pain. I had lots of issues with the FitContributor and displaying custom values in GC, but GCM always seemed to work. I had problems displaying a string in GC and eventually gave up, but it sounds like you are trying to display floats? When trying to show a string like 00:10 hh:mm GC would show 0 hh:mm, but GCM always worked.
    One thing I did notice is that after I made any changes to the fit contributor part of my code, I had to uninstall the app from my watch, reboot and then reinstall the new version. If I just updated the new version without an uninstall, then GC wouldn't show any custom values at all (just the Recorded with: MyApp logo). But GCM always worked right away.
    The process seems a little flaky on GC for sure, but I'm pretty happy that we can display custom values on GC and GCM.
    Sorry I can't be any more help...maybe post the FitContributor part of your code?
  • @TRAVIS.VITEK: the problem I have with fit files I contributed to is, that 3rd party tools have problems reading it. E. g. the set of fit files I added a string to each lap can't read by sporttracks (offline tool). Strava shows only the first lap and online tools like http://garmin.kiesewetter.nl/ throws an error message while loading:
    The file could not be uploaded. The following error occured: Exception of type 'System.OutOfMemoryException' was thrown.
    Further example; the set of fit files (e. g. this one: https://connect.garmin.com/modern/activity/1372956586) I added values each second can't also not read by sporttracks, Strava shows them correctly but online tools like http://garmin.kiesewetter.nl/ throws an error:
    Upload status: The file could not be uploaded. The following error occured: Failed to enable constraints. One or more rows contain values violating non-null, unique, or foreign-key constraints.
    @bwd1: I have two datafields which contribute to the fit file:
    1. I add a string at each lap:
    <fitContributions>
    <fitField id="0" displayInChart="false" displayInActivityLaps="true" sortOrder="0" dataLabel="@Strings.HrLabel" unitLabel="@Strings.HrUnit"/>
    </fitContributions>
    In the constructor:
    avHrField = createField("different_HRs", 0, FitContributor.DATA_TYPE_STRING, { :mesgType=>Fit.MESG_TYPE_LAP, :count => 14 });
    avHrField.setData("0");
    And in the onTimerLap() method (avHr, and averageCadenceField are also numbers):
    avHrField.setData(avHr + ", " + temp.toNumber() + ", " + averageCadenceField);
    By the way: I put this code in the onTimerLap() method, nevertheless, it seems that the fit file is written __before__ this code is executed which means that the data is written to the next lap :-( Is this a bug or a feature and is there a workaround for this?
    _________________________________________________________
    2. I create in another app a graph:
    <fitContributions>
    <fitField id="0" displayInChart="true" sortOrder = "0" precision="0" chartTitle="@Strings.AvHrGraphLabel" fillColor="#FF0000"/>
    </fitContributions>
    In the constructor:
    avHrField = createField("average_heartrate", 0, FitContributor.DATA_TYPE_UINT8, { :mesgType=>Fit.MESG_TYPE_RECORD, :units=>"bpm" });
    avHrField.setData(0);
    In compute(info):
    avHrField.setData(hiAvHrField.toNumber());
    The problem here is, that (as you said) GC mobile shows the value correct, but GC web shows the curve not in red but in black. If I use the zoom button for that black graph, no curve at all is shown. Nevertheless, if I hover with my mouse over the not shown curve, the values at the cursor position are shown.
    Apart from the GC web problems I have problems with 3rd party tools and those fit files (as stated above).
    Thanks for your help in advance.
  • Ah, yeah I couldn't get FitContributor.DATA_TYPE_STRING to work in GC either (GCM was fine). As Travis mentioned, it may be a bug in GC.
    I also tried FitContributor.DATA_TYPE_UINT8 but had no luck, but FitContributor.DATA_TYPE_FLOAT worked fine for me. I'm not doing any laps though.
    Also my colour worked:
    <fitField id="0" displayInChart="true" sortOrder="0" precision="1" chartTitle="@Strings.waveplot_title" dataLabel="@Strings.waveplot_label" unitLabel="@Strings.waveplot_units" fillColor="#0000FF" />
    Gave me a blue graph.
    The zoom button on your IQ graph works for me, other than the colour is black.
    As for sporttracks, my values don't show there either but I didn't really expect them to. I would email support at Sporttracks. They have always been very quick to respond and would probably be interested in looking at the FIT file.
  • Thanks for sharing this. I just want to record numbers. Do you convert those floats to numbers by e. g. 123.0 ? Or is it possible to set the precision in the resources file to 0 but stating in the code FitContributor.DATA_TYPE_FLOAT? Do you have a screenshot of one of your graphs?
    I also start my string with a number. Maybe GC web interpretes the string different from GCM and can not depict strings which starts with a number. In my example I create strings like: "141, 136, 150". What GC web depicts is "0". Maybe it's worth to create stringls which starts with a letter like "H141, 136, 150". What do you think?
    @TRAVIS.VITEK: Do you know a workaround for that:
  • The zoom button on your IQ graph works for me, other than the colour is black.
    Really? Which browser? Can you send me a screen shot?
    Regarding sporttracks: what I mean is, that not only the values are shown but the entire FIT file is not readable. It is refused. Regarding contacting them: that's a great idea.
  • <fitContributions>
    <fitField id="1" displayInActivitySummary="true" sortOrder="1" precision="0" dataLabel="@Strings.wavenum_label" unitLabel="@Strings.wavenum_units" />
    <fitField id="2" displayInActivitySummary="true" sortOrder="2" precision="2" dataLabel="@Strings.wavetime_label" unitLabel="@Strings.wavetime_units" />
    <fitField id="3" displayInActivitySummary="true" sortOrder="3" precision="0" dataLabel="@Strings.wavetime2_label" unitLabel="@Strings.wavetime2_units" />
    <fitField id="4" displayInActivitySummary="true" sortOrder="4" precision="1" dataLabel="@Strings.wavedist_label" unitLabel="@Strings.wavedist_units" />
    <fitField id="5" displayInActivitySummary="true" sortOrder="5" precision="1" dataLabel="@Strings.wavespd_label" unitLabel="@Strings.wavespd_units" />
    </fitContributions>
    function initialize() {
    DataField.initialize();
    waveplotField = createField("waveplot", 0, Fit.DATA_TYPE_FLOAT, { :mesgType=>Fit.MESG_TYPE_RECORD, :units => "kph" });
    wavenumField = createField("wavenum", 1, Fit.DATA_TYPE_FLOAT, { :mesgType=>Fit.MESG_TYPE_SESSION });
    wavetimeField = createField("wavetime", 2, Fit.DATA_TYPE_FLOAT, { :mesgType=>Fit.MESG_TYPE_SESSION });
    wavetime2Field = createField("wavetime2", 3, Fit.DATA_TYPE_FLOAT, { :mesgType=>Fit.MESG_TYPE_SESSION });
    wavedistField = createField("wavedist", 4, Fit.DATA_TYPE_FLOAT, { :mesgType=>Fit.MESG_TYPE_SESSION });
    wavespdField = createField("wavespd", 5, Fit.DATA_TYPE_FLOAT, { :mesgType=>Fit.MESG_TYPE_SESSION });
    waveplotField.setData(0);
    wavenumField.setData(0);
    wavetimeField.setData(0);
    wavetime2Field.setData(0);
    wavedistField.setData(0);
    wavespdField.setData(0);
    function onTimerStop() {
    wavenumField.setData(WAVES_TOT);
    wavetimeField.setData((TOT_TIME2/60)%60+TOT_TIME2%60/100.0);
    wavetime2Field.setData(OL_MAX_T);
    wavedistField.setData(OL_MAX_D);
    wavespdField.setData(OL_MAX_S);
    Results are shown here:
    https://forums.garmin.com/showthread.php?220947-Data-Field-Surf-Tracker&p=907434#post907434
    So yes, I used FLOAT then set the precision. I had to get tricky with my hh:mm string.
    For sporttracks, I have it synced to GC and it syncs and displays the FIT file as normal (without the custom values). I didn't try importing manually.
    I'm using Chrome on Win7:
