github.com/.../progress.mc
sometimes run sometimes timeout
I use vivoactive 4 for actual usage testing.
This could be due region as I created heroku app based in europe, but in course of testing with vpn even from us it runs at my end.
I'm sorry. you haven't put enough code to analyse. I have to guess what is in code....
You have to decide - if you want help from others you can't make code secret.
It is not a hidden I made whole repository publicly available Repository.
what is the correct url to fetch data?
it starts with https://kauno-autai.herokuapp.com/stopActivity/ and on the end i enter stop name, and server returns stop activity. I use vilniaus, or utenos as actual stops, but you can enter anything it will respond, but schedule array will be empty if no nearby stops will be matched.
Did you changed anything in code?
no, in properties, I've removed ' g.', Is it url parameter?
