github.com/.../progress.mc
Empty? You don't see the request going out?
What happens with the WebRequest sample when run in the sim? That should check the basics work on your system without proxies, etc involved.
Probably you uncheck option in firewall when you first time run simulator. Correct windows firewall
I checked both marks on Private and public networks. Are you suggesting on leaving them unchecked?
In sample app with both original link and my proxy server there is a traffic in simulator.
1. exit form sim
2. remove sim from firewall
3. run app in sim
4. firewall windows will appear check both checkboxes
Try it with the firewall off just to see if it works. If it does, you probably can set things specific to the sim (I use another firewall so not sure).
with disabled firewall still no traffic I even restarted pc but still not successful.
so put your url to sample app and check if it also run
