Need help with a heart rate alarms app
Hi there,
I've recently bought Forerunner 745 and got disappointed by the fact that there is a "bad" irregular hear rate alarm feature. Actually, it allows to set a top level starting from 100 bpm only however I really need to set it from 80 (kindly don't ask why).
So now I'm looking for any way / hack to get what I want. I've deployed the Garmin development environment and now trying to create my own app to achive this.
I've already sorted out how to recieve the current heart rate and vibrate the watch if it is greater than 80 bpm. It works fine in the emulator but I don't know how to get it working on the watches in spite of my app is copied to the watches.
In a nutshell, I need a simple background app which monitors my heart rate and start vibrating when it gets > 80 in 24/7.
Can you please give me some architecture ideas how to do it: what kind of app it should be, which methods to use? P.S. I don't need a special watch face, only background mode all the time.
  • True, but they probably also take into account the time it takes to implement something. And frankly changing a constant in the code is not too difficult even if they have to to test it afterwards.
  • Settings of health metrics should have a reasonable scientific background. I think the reason for setting the upper limit of resting HR at 100 bpm is:
    "The American Heart Association states the normal resting adult human heart rate is 60–100 bpm. Tachycardia is a high heart rate, defined as above 100 bpm at rest. Bradycardia is a low heart rate, defined as below 60 bpm at rest. When a human sleeps, a heartbeat with rates around 40–50 bpm is common and is considered normal."
    en.wikipedia.org/.../Heart_rate
    And Garmin always points out that the watches aren't medical devices, to avoid possible compensation for damage to health. So I don't think Garmin will change this limit or make it adjustable.
  • this maybe explains why 100 is the default, but not why it can't be set to a lower value
    Of course it's easy to change the constant in the program, but
    1) The F745 is a Sports & Fitness watch
    Garmin about F745: "This GPS running watch is made for runners and triathletes like you who need detailed training stats and on-device workouts plus smartwatch functions."
    and the option is called "Abnormal Heart Rate Alert".
    www8.garmin.com/.../GUID-A1C8190D-D4D6-4EE4-9B31-87AE009433AA.html
    2) The threshold for abnormal heart rate at rest is defined by the AHA at 100 bpm.
    3) The F745 isn't approved by the FDA for cardiac event recording.
