Edge 530 Bluetooth sensor app - change in behaviour after restart
HI
First let me start by saying i'm not a developer. An acquaintance wrote a connect IQ app to record data from a Bluetooth sensor (Data Field app type). It is not a published app, and I have been using the app fine without problem on a Garmin Forerunner 645 via sideloading into the Apps folder on the device. It's worked perfectly for my needs, notwithstanding some limitations of the Forerunner itself. I recently also got a Garmin Edge 530 device to run the app as that would address the Forerunner limitations, but trying to run the app is giving some issues (even though it was simulated on Edge 530 when he wrote the app).
After side loading the app on Edge 530, the bluetooth sensor pairs fine and app works as intended. However as soon as i restart the device, the device no longer pairs with the Bluetooth sensor. If i reconnect the device to my PC and look in the Apps folder, i no longer see the app filename in that folder. However, on the Garmin Connect Mobile App - the app is still listed on the device. If i uninstall the app from the Garmin Connect Mobile App, then reload it - same thing - it connects fine on first try but as soon as device is restarted, it cannot pair for some reason.
Any ideas on what may be causing this and why it is working on the FR645 but not the edge 530 and/or what may be the best way to troubleshoot it?
I'll need the other person to update the source code, but given they were helping me out - i want to try narrow down what is likely to be done in advance.
Thanks
Ryan.
