I notice that some Garmin Apps on the F7/Epix Gen2 range display the ability to turn off the touch screen:
Is that functionality available in the Toybox API?
The safest approach is to allow both buttons and touch, as you'll likely have users that prefer buttons, touch, or use both.
Nope, that's just not an option for me: I have too many…
Isn't programmatically disabling touch just intercepting touch messages and returning true without actually doing anything?
I suspect that's a picture of a native activity,
Yes, it's the Garmin "Boating" app.
can disable the touch screen in the simulator with…
If i swipe left on Fenix7, input test app from SDK shows that input is KEY_ESC :( which obviously i wont disable
Hmm, I assume that's the unmodified Input sample on the real device? That doesn't happen in the sim. I do get onBack for right swipe. (onBack is also associated with the back button, which also triggers KEY_ESC.)
So I noticed that in the input sample (on the sim), even though onSwipe() returns true, the corresponding behaviors for the various swipes are still triggered (onBack, onNextPage, onPreviousPage).
So I was wrong, you can't just return true from all the touch handlers in order to "ignore touch". Sorry about that!
If you really want to "disable touch", I think you would have to avoid using behavior handlers such as onNextPage() and only use onKey(). Except even that wouldn't work if any touches actually trigger onKey on a real device (which I would consider a bug).
And that would probably be a major refactor, plus it could present problems on old or obscure devices with weird key mappings.
Sorry for the bad advice! I should've tried the input sample.
So I'll do a 180 and agree with all of the ppl in this thread who would like the ability for CIQ apps to explicitly disable touch.
I do wonder if it's a bug that returning true from various touch handlers doesn't cause the corresponding behavior or key handler to be skipped. Because last time I checked, if you handle a key, the corresponding behavior handler is not called.
I meant swipe rgiht... sorry.. My goal is to avoid going back when water hits screen (as it is happening at the moment). Thus i ended up with solution (not a clean one.....)
I made this TouchAwareBehaviorDelegate gist: https://gist.github.com/flocsy/40f4d1082187a35336f3c4813e1ddccc
You'll get the idea and if you need more actions you can easily add them.
