Issues with sdk 4.0.6, VSCode and MonkeyC plugin 1.0.0 for MAC
I'm experiencing multiple issues with a combination of SDK 4.0.6, MonkeyC plug 1.0.0 on VSCode on a MAC.  Is anyone else?
- Launching an app from VSCode does not appear to be picking up the right reference in my jungles file - or does not recognise the App connected to the source file I currently have open.  It builds for a completely different App.  Does not happen with MonkeyC plugin 0.1.13 (and SDK 4.0.6)
- When the simulator loads I'm presented with a blank window.  I have to shutdown and restart the simulator, sometimes multiple times.  Does not happen with MonkeyC plugin 0.1.13 (and SDK 4.0.6)
- With SDK 4.0.6, double-clicking the memory stats at the bottom of the simulator window causes the simulator to crash and generate a problem report to apple.  This does not happen with sdk 4.0.5.
VSCode does not let me rollback the MonkeyC plugin to anything more recent than v0.1.13 (even if I uninstall and reinstall).  I'm not sure I should even be able to select 0.1.13 and SDK 4.0.6 in combination, but I can.
My environment:
macOS v11.6 (macbook pro 2019)
VSCode v1.61.1
Connect IQ SDK 4.0.6
MonkeyC VSC Plugin 1.0.0
Java 1.8.0_271
  • When you go to extention settings, you can go to folder and set the settings.  I've not tried this, but it looks like you can set typeCheckLevel for a project here per project.
    Here's what you see with the type check level.
    It might be nice if this was compiler flags though, so it wasn't just type checking per folder (-l), but you could also set things like the new profiler per folder (-k)
    side note.  You don't need to use -k for the profiler.  You can also run it in the sim, under the file menu (file>View Profiler) then start it, let it run for a while then stop it.
  • Brilliant!  thanks Jim, that works a treat.  I had to set it to "Default" in User and Workspace, and then set it individually for each of my folders.  That definitely saves some clicks and time
