Position.Info.when Problem
Hi,
I am getting an issue with the call Position.Info.when
The simulator is correctly returning the current date and time (from when the FIT Simulation starts). However my Vivoactive always returns 19/Jan/2038 03:14 (the max 32bit value) even when the GPS accuracy moves from Not Available to Good.
Any ideas?
Cheers
Chris
  • Posting in these forums is your best bet. I personally think it helps if you put something in the title of the issue to call out that it is a bug (I use [CIQBUG] as a prefix in the thread title). If you could supply a buildable example program that demonstrates the problem, that makes it easier to confirm the issue, which is very helpful.
    As I've mentioned, this has already been filed, so I wouldn't do it for this particular issue unless you want to use up some of their time to verify the process works.
    Travis
    Travis
    No, I won't waste their time and hope to get the solution a Little earlier. :)
