Hey!
I am sorry if this is a dumb question or anything. But i simply want to test out and use the method makewebrequest but cannot make it work. I constantly get responseCode -400 and data that is null. My code is following (Its based on the template given from eclipse):
function getInitialView() {
var url = "https://www.bing.com";
// this is the data that you want to send out
var params = {};
var options = {
:method => Communications.HTTP_REQUEST_METHOD_GET
// make the Communications.makeWebRequest() call to send data
Communications.makeWebRequest(url, params, options, method(:onResponse));
//Template stuff
//return [ new dataRetrieveView(), new dataRetrieveDelegate() ];
function onResponse(responseCode, data)
System.println("in onReceive, responseCode=" + responseCode + ", data=" + data);
I have tried using different content-type and responseType, but i keep getting -400...
So i tried not setting any of these as i read that "if the content type is not specified, it will default to "application/json" for GET" and that if responseType is not given the system will attempt parsing the response both as JSON, then as URL ENCODED.
How should i modify this example to not get responseCode -400 constantly? Can i not use bing as an example?
Please help me, i am confused and frustrated
