Maybe someone sees an error here, I don't see any. The function is null safe, does not make any calculations (no 0 division) and looks like following:
static function formatSpeed(setup, speedInMeterPerSeconds) {
var settings = System.getDeviceSettings();
var unit = "m/s";
var speed = speedInMeterPerSeconds;
switch (setup.windSpeedUnit) {
case 0 /* WIND_SPEED_UNIT_SYSTEM */: {
if (settings.temperatureUnits == System.UNIT_STATUTE) {
if (speed != null) {
speed *= 2.23694; // m/s => miles/hour
unit = "mph";
break;
case 1 /* WIND_SPEED_UNIT_MS */: {
// passt
break;
case 2 /* WIND_SPEED_UNIT_KMH */: {
speed *= 3.6;
unit = "km/h";
break;
case 3 /* WIND_SPEED_UNIT_MPH */: {
unit = "mph";
break;
case 4 /* WIND_SPEED_UNIT_BEAUFORT */: {
var bft = 0;
if (speed == null) {
} else if (speed < 0.3) {
// passt
} else if (speed < 1.6) {
bft = 1;
} else if (speed < 3.4) {
bft = 2;
} else if (speed < 5.5) {
bft = 3;
} else if (speed < 8.0) {
bft = 4;
} else if (speed < 10.8) {
bft = 5;
} else if (speed < 13.9) {
bft = 6;
} else if (speed < 17.2) {
bft = 7;
} else if (speed < 20.8) {
bft = 8;
} else if (speed < 24.5) {
bft = 9;
} else if (speed < 28.5) {
bft = 10;
} else if (speed < 32.7) { // <= line 313
bft = 11;
} else {
bft = 12;
speed = bft;
unit = "Bft";
break; // <= line 320
case 5 /* WIND_SPEED_UNIT_KNOTS */: {
speed *= 1.94384;
unit = "kn";
break;
return DataField.EMPTY + unit;
} else {
return speed.format("%d") + unit;
I marked line 313 and 320 (line 60 + 67 in the code snipplet) from my source code, in those lines I get following exception: Error Name: Invalid Value
Any ideas how this can happen? As the code above looks save for me, this seems to be something with a misleading stacktrace, but I have no idea where I can look further in this case...
