I really don't understand your answer. I can create identical workouts, one with Garmin Connect and one with the built in Interval training. The default screen is different. If what you say is true I would think the screens would be the same.
None the less, is there anyway to create a countdown timer & lap counter (correct one, like the built in on on the interval training) data fields? I can create separate screens (not the default one, which is ok), I just can't add a countdown timer or have the lap count just the work event and not the rest.
I think it would be much easier for everyone if you completely and accurately described what you want. I've re-read your first few posts and the only thing I can conclude is that you want a countdown timer and a lap counter data field. Everything else is a blur.
The countdown timer you want seems simple enough, but you've never described where the timer data (specificially the timer period) will come from. Are you envisioning that this information will come from the active workout interval? If not, where would it come from?
Again, the lap counter you're proposing isn't really a lap counter. It sounds more like a repeat counter. If your workout is something like (5:00 @ Z4, 1:00 recover)x4, you want it to display 1 during the entire first 6 minutes, then 2 for the next 6, and so on. What if the workout is more complicated, like (5:00 @ Z4, 1:00 recover, 3:00 @ Z5, 3:00 recover)x4. What I've described would display 1 for the first 12 minutes, and what you've proposed would display 1 for the first 6 minutes, and 2 for the next 6 minutes. That's not even counting nested repeats. Regardless, how would the data field know what lap/repeat you are on? Are you envisioning that this information would come from the active workout? If not, where would it come from?
As far as I can tell, everything you're asking for is already done automatically by the built-in workout system, regardless of how the workout is created (Garmin Connect or directly on the device). If you set the workout duration to a time, you get a countdown timer. If you use a repeat in the workout, it displays the current repeat that you are working on as an overlay. If this is the case, I fail to understand why someone would write these data fields as they directly duplicate functionality that is already available.
If you are trying to avoid creating workouts, but you want the functionality provided by a workout, I'm not sure how to help. Even if you don't create a workout in Garmin Connect or on the device, information about the workout would need to be communicated to the data field so that it knew hat the initial countdown timer value would be and so that it could determine the current repeat.
So either I'm way off base, or you need to provide some more information. I'm happy to be wrong.
Travis
Travis ,
That is why I tried tho ask how to do a count down time that uses the workout created with garmin connect.
