Communications transmit queue full
Hello, I'm receiving this message in the logs:
WARNING: Communications transmit queue full
STORE_ID: 00000000000000000000000000000000
What does it mean? When does such an error occur?
Is there a limitation on the data that can be transmitted via BLE to the companion app?
    I can't say at this point if the performance you are seeing is expected or not. I can say that the performance is probably not going to match with devices that are using the 2.1 specification, and we have see issues with latency, particularly with backgrounded iOS apps that do not appear to be under our control at this point.
    Our current investigation on Android is yielding inconsistent results (0.5-4 seconds), so we are continuing to work to determine if our end is responsible or not when there are delays.
