Extremely Serious Bug in Monkey C!!!
Let's take such class:
class A
  hidden var myLocal = "Var from A";
  function do_localModyfication()
    myLocal += " + some modyfication";
Then write next class:
class B extends A
  // completely by accident
  hidden var myLocal = "Var from B";
  function test()
    do_localModyfication();
    System.println(myLocal);
How do you think what you'll see in the log after B.test() call?
You will see: "Var from B + some modyfication" :confused::p !
And at the end imagine that you are using class for which you have no sources, like View or WatchFace. Please Garmin, tell me if I should pray that my var names are different than yours? Otherwise, your class and mine will explode!
This of course is a BIG BUG and we should only see: "Var from B"
I wonder why Garmin didn't decided to chose eg. C# which is free. Writing in C# if you build your program without warnings you can assume that it will work as intended. In my opinion Monkey C (Java like) it's probably not the best choice and may leads to unstable software.
Peter
  • Hello.
    I'm new here and I started a project with ConnectIQ and MonkeyC. What is the status of this thread?
    the most emergent concern we have is name collision with undocumented class or module variables
    I like quality and reliable code (and hate relying on debugging) so I'm trying to prepare my development by reading about what I should and what I should not do. I'm trying to avoid any "bad surprises"...
    That's why even if this "bug" is old, I would like to have a status update.
    I guess it has been "fixed" or at least, there is a standard way of avoiding name collisions
    Thank you !
