Time to prepare for the new devices and see what bugs were fixed and what new ones we can find.
I'm not seeing this, at least in a watch face. I still get null if there's no GPS. ("info" isn't null, currentLocation is)
		var info=Activity.getActivityInfo();
		if (info != null && info.currentLocation!=null) {
			var degs=info.currentLocation.toDegrees();
			Sys.println("degs="+degs);
		} else {
			Sys.println("null loc");
What kind of an app are you seeing this in?
Wow sounds great,
Does Garmin fix the problem with compatibility on the store ? I cant access right now to the log may be it is in it.
These are the full release notes (no mention of the store - although I have noticed that in the run config options now I can't select to run on Fenix 6 as 3.0.x only 3.1.x, and I think before I could select both?)
General Changes
Simulator Changes
Compiler Changes
In a WatchFace. My code is pretty much the same as yours. I can't reproduce this on sim as for some reason sim displayed that it runs on 3.1.6 despite I have updated everything on 3.1.7.
But since 3.1.7 was released, I started to get 0.0 in logs on f6 and v4 devices. I assume that this happening when the application just installed on the device and trying to get access to uninitialized GPS.
I'm not seeing this with a watchface in either the 3.1.7 sim or on a va4 with the latest firmware. I added this to onUpdate()
		var degs=null;
		dc.drawText(width/2,150,Gfx.FONT_XTINY,""+degs,Gfx.TEXT_JUSTIFY_CENTER);
So I can see what's going on from the watch face. Without a location, I see null, with a location, I see lat/lon.
Post your code, as maybe it's something about how you're saving a location in Storage. Like maybe saving [0.0] if you don't have a location yet, and the next time, it reads that from Storage.
That would surprise me as this code worked for years with no change and I started to get [0,0] on 3.1.7 only
var activityLocation = Activity.getActivityInfo().currentLocation;
		if (activityLocation != null)
   			      Setting.SetLastKnownLocation(activityLocation.toDegrees());
    	}In a watch face, GPS is never turned on, so there's no "starts initializing" - you are getting the info from the last activity.
The thing is what you're seeing likely has nothing to do with the SDK, as it sounds like you're still on 3.1.6, but the watch might have a 3.1.7 VM.
