ERA reports some cases of unhandled exception from Application.Properties.getValue() in onLayout()
I'm getting some ERA reports of an unhandled exception when calling Application.Properties.getValue() from onLayout() - but I've no idea why it could be happening ...
It is happening in both an app and a watchface - and it's always on the very first call to access the properties after starting up.
The property is defined in the properties.xml just like normal:
    <property id="pg" type="boolean">false</property>  <!-- position got -->
And is accessed just with a normal call:
    var v = Application.Properties.getValue("pg");
It clearly works for most people using the app, but why are there some instances of exceptions being created?
The documentation says these are the possible exceptions:
  • (Toybox::Lang::UnexpectedTypeException)
    Thrown if key is of type null, Array, or Dictionary
    (Toybox::Application::Properties::InvalidKeyException)
    Thrown if key does not exist in Application Settings
Is there some other exception possible here?
Any suggestions for how I could debug this?
  • It's indeed a property with no settings. I'm using them to define devices that are OLED, or has no floors, or if they are square or round,... So I define those properties based on jungle files etc. Using a try/ catch is an option, but then it results in other errors are weird layouts because I actually need the correct device information.
    Is there a better way for doing this?
    If I understand correctly, properties should only be used for actual settings?
  • Just to show you an alternative way to handle device specific source code and definitions:
    What I do to define device specific constant data is following:
    fenix7x.sourcePath = $(srcBase);../../shared/src-devices/fenix7x
    fenix7x.resourcePath=$(resBase)
    fenix6xpro.sourcePath = $(srcBase);../../shared/src-devices/fenix6xpro
    fenix6xpro.resourcePath=$(resBase)
    enduro.sourcePath = $(srcBase);../../shared/src-devices/enduro
    enduro.resourcePath=$(resBase)
    And then I have a DeviceInfo.mc file for each device like e.g. following:
    class DeviceInfo {
        static const MODEL = 10 /* fenix6xpro */;
        static const DEVICE_NAME = "Fenix 6X";
        static const SIZE = [280, 280];
        static const HEIGHT_FONT_OVERLAY = 8;
        static const SUPPORTS_PARTIAL = true;
    	static const HIGH_MEMORY = false;
  • Well that's a very good alternative. I honestly did not now about the option for sourcepath. Very interesting!
