TimeZoneOffset Question
There are situations I've discovered where a Garmin device's Activity Elapsed Time is wrong. Seems to be a weird bug under some corner cases that involve hitting the lap button when stopped, or putting the activity to sleep then resuming it.
The more consistently accurate way to get an activity's elapsed time is to grab the difference between the current time and the start time.
TWO ISSUES with this:
1. activity spans the standard -vs- daylight savings time shift. I'm guessing the start time remains fixed, and the current time can shift +/- an hour.
2. activity crossing a timezone. Again, guessing the start time stays fixed in the starting TZ, and the current time shifts +/- an hour.
There is a timezoneoffset() function returned in seconds. anyone know if this function adjusts continuously across a particular timezone - shifting a few seconds every mile traveled east or west? or just at the TZ boundaries?
I think I'll just go with the system elapsed time and not try to code a complex work-around for a bug.
  • Thank you very much, I will then use only the timezoneoffset, it is enough for the task.
  • Anyone know if there s there any update to this issue ?
    BST has caught me out as everything worked well in the sim but was an hour out after BST on the watch
    Im using the below, works in the watch but not the sim (hour out)
        var TimeUTC =  Time.now().value()    ;
        var tzo = System.getClockTime().timeZoneOffset;
        var TimeNow = TimeUTC + tzo;
    I set location and weather location in the SIM but i have still not found a way to make the sim and the watch do the same thing.
    Laptop is set to UK etc etc. what else can I do so that I dont have to change code between a watch and a SIM?
  • The difference between the sim and the device. In once case, the timeZoneOffset includes the dstOffset and dstOffset will be 0. In the other, timeZoneOffset doesn't incluse dst.
  • so a function which gets offset and checks dst is required to manage this? Has anyone made this as it sounds beyond my skiils
  • Where you now use System.getClockTime().timeZoneOffset, use (System.getClockTime().timeZoneOffset+System.getClockTime().dst).
    That should work on both the sim and device.
  • i'm on the UK, the above gives 7200 (in the sim) which is 2 hours. BST is 1 hour ahead of UTC, what am i missing?
  • put in some println calls with the two values and create a log on the real device so you can see the two values.
  • Here are scenarios I haven't been able to test but am curious about:
  • My 2 cents:
    - Most computer systems internally keep time in UTC and convert to local time for display purposes (inb4 “there are systems from the 1980s which only store local time and/or are unaware of UTC”)
    - A notable exception to the previous point would be something like a calendar appointment, which would naturally store local time and an associated time zone. Same with daily fitness / activity tracking, which of course would take local time into account to determine the end/start of a day (and ofc there have been bugs associated with this)
    - Garmin FIT file timestamps are in terms of UTC (seconds since the Garmin epoch), and I wouldn’t be surprised if internal time was kept in UTC as well
    - I’d guess that the majority of duration-related operations on a Garmin device are timezone-agnostic, unless there’s a specific reason that time zones have to be taken into account
    So my guesses for your questions would be:
    (EDIT: clarity)
    1) no I think it will do the first alternative you listed (the right thing)
    2) no I think it will do the first alternative you listed (the right thing)
    3) doubt it, unless you have a way to get the coordinates of the next point, in which case you could use a LocalMoment on newer devices to determine the local time at that point.
  • Good insight! I assume by "no" you mean it will do the right thing. I agree.
    For #3, the coordinates are in the route. Given the LocalMoment feature, that would be really nice to get "coordinatesAtNextPoint()".
