Firmware 3.0 für Edge 1000 veröffentlicht
Hi,
Update hier veröffentlicht:
http://www8.garmin.com/support/download_details.jsp?id=6735
Freiwillige vor ...!
Bin vor allem auf die Änderungen bei der Höhenmeterberechnung gespannt ...
Changes made from 2.80 to 3.00
New feature! Added the ability to update sensor software on supporting sensors which includes Vector power and HRM-Run sensors.
New feature! Added the ability to configure Vector features. Turning off the Cycling Dynamics setting will help to extend Vector battery life. To do so, select Settings > Sensors > [your Vector sensor] > Sensor Details > Vector Features > Cycling Dynamics.
Due to the previous change, cycling dynamics, torque effectiveness and pedal smoothness capabilities for supporting Vector power sensors will need to be re-enabled. These new settings can be found in the Settings > Sensors > [your Vector sensor] > Sensor Details > Vector Features menu.
New feature! Added the ability to pair Vector S and Vector 2S pedals to a Vector upgrade pedal through the Edge 1000
Improved the accuracy of the ascent and descent calculations.
Fixed bug preventing downloading training plans over Wi-Fi.
Fixed bugs and made improvements to the Elevation graph page.
Improved turn guidance instructions.
Fixed issue where parts of map files would not load. This issue could be seen on devices that contained large map files such as the GB Discoverer Premium 1:25K maps.
