if you compare the Quatix Loudness to other watches, it has a very low alert sound. That doesnt make any sense, in case you are using it for a regatta.
This results in nearly every alarm, that is to quietly if you have talking or music around.
Does anyone else encounter the same problem?
And secondly will there be a solution for that problem( e.g. select another alarm sound)?
Regards
Klaus
