Firmwareversion 4.50 (Oregon x50)
http://www8.garmin.com/support/download_details.jsp?id=4523
Download:
http://www.garmin.com/software/Oregonx50_WebUpdater__450.gcd
Changes from version 4.20 to version 4.50:
Updated magnetic Earth field data
Improved GPS performance
Improved support for BirdsEye™ Satellite Imagery (each provider's imagery can be configured independently)
Increased the maximum number of supported JNX files to 250 from 200
Fixed issues with WAAS/EGNOS
Fixed issue with track navigation sometimes not adding waypoints to the Active Route list
Fixed issue with MPC map labels disappearing
Fixed shutdown on the map page when you have a geocache dashboard active and return after pressing the geocache name
Fixed issue with moon not showing on sun and moon page
Fixed issue with photo viewer not displaying correctly
Fixed issue with progress bar displaying properly on power up
Fixed issue with waypoint distances showing significantly off in the waypoint manager
Fixed issue with 3D view
Fixed issue with track navigation not adding waypoints to the Active Route list when they are exactly equal to a track point
Fixed shutdown when more than the maximum number of JNX files were present
Fixed 'Search Near' functionality on Hunt & Fish and Sun & Moon pages
Fixed shutdown related to topographical maps and land cover text size
Fixed shutdown associated with certain custom POI files
Fixed Glide Ratio to Destination field
Fixed problem with profiles and the fields on the map page
Fixed an issue with magnetic north reference and waypoint headings
Fixed shutdown on the map screen when a waypoint was being moved to the same location as a geocache or other POIs
Fixed an issue with archived tracks not displaying properly
Fixed an issue with having too many custom symbols on the device
Fixed an issue with renaming a waypoint immediately after creating it
Modified the 'Arriving at Destination' message banner so that it no longer appears when navigating to a geocache
Zielsuche -> Fotos stürzt immer noch auf der dritten Seite ab.
    Zieleingabe im Vorführmodus, wenn noch keine Sats gefunden wurden:
    - Es wird keine Entfernung zum Ziel gezeigt
    - Bei Luftlinie funktioniert "zu Position gehen" nicht
    Ein mit BaseCamp gemalter Tracks, der mit dem Oregon eine andere Farbe bekommen hat, produziert in BC Fehlermeldungen und wird nicht importiert.
    Beides habe ich unter "Fehler melden" angemeldet.
    In der Systeminfo steht Software 4.5, GPS-Software 5.0
    Geht man auf die Diagnoseseite (Sat-Seite oben links drücken) steht da GPS-Software 320
    :confused:
    Den Fehler gibt es ja schon länger.
    Nachdem (wenn ich richtig gezählt habe) mittlerweile zwei BC Updates und ein (oder schon zwei?) Firmware Updates gekommen sind, seitdem das hier gemeldet wurde, glaube ich nicht mehr daran, dass Garmin das beheben wird (oder kann?)
  • Lud mir heute die neue Firmware auf das Gerät und fand glücklicherweise hier im Forum eine Beschreibung,welche Änderungen darin enthalten sind; zuvor versuchte ich vergeblich auf verschiedenen Webseiten von Garmin diese Angaben zu finden.
    Kann mir jemand sagen, wo die Details eines Firmwareupdates veröffentlicht werden?
    Bin offenbar zu blöd, die Stelle zu finden.
    Vielen Dank
    Die URL steht über der Liste der Änderungen oben im ersten Posting.
    Ausserdem wird die Liste während dem Update durch den WebUpdater auch angezeigt.
    Hallo zusammen,
    ich habe jetzt die neue F.W. 4.50 drei Tage drauf und muss sagen die Position Genauigkeit
    ist gegenüber der letzten Beta Version besser aber das ist meine Persönliche Ansicht dazu.
    Was mir aber aufgefallen ist, ist das der Positionspfeil beim anhalten sich um ca. 25 Grad im
    Uhrzeigersinn dreht und dort verharrt bis man wieder in Bewegung ist. Das war mir
    Vorher nicht so aufgefallen ist das so normal? dann was mir noch aufgefallen ist das erst
    nach 3sec. Stillstand und dann in Bewegung sich der Positionspfeil mit bewegt das war vorher
    nicht so. Ich hatte nach der neuen Version 4.50 einen Hardreset ausgeführt trotz dessen
    verändert sich nichts an der Sachlage, hat vielleicht einer von euch eine Idee oder kann
    mir vielleicht sagen was ich eventuell Einstellen muss das der Positionspfeil sich nicht dreht
    und in der Gehrichtund stehen bleibt wenn man anhält sowie das er sich sofort in Bewegung setzt
    wenn mann wieder geht.
    Im Voraus vielen Dank für eure Antworten.
    Gruß aus Köln
    Markus
    Hallo zusammen,
    ich habe noch Fragen vielleicht kann mir ja einer von euch die Beantworten.
    Also ich habe einen Garmin Oregon 550 mit der Aktuellen F.W 4.50, ich
    habe heute ein paar Cache gemacht und musste feststellen das sich die
    Karte immer hin und her bewegt d.h. wenn man einen geraden Strich
    von 6 Uhr auf 12 Uhr ziehen würde und er dann immer zwischen 11 Uhr
    und 13 Uhr hin und her schwenken würd. Nach erneuten Kalibrien des
    Kompass im freien hat sich nichts an der Situation geändert.
    Bei der F.W. 4.20 war das nicht so oder täusche ich mich da.
    mir ist weiter Aufgefallen das der Positionspfeil in der Zoomstufe von 20m.
    sehr schleppend sich in Fortbewegungsrichtung mit bewegt.
    Ich denke wenn dies auch bei euch so ist das es vernünftiger wär ein Downgrade
    auf die alte 4.20 durchzuführen, hat einer noch eine oder weiß wo ich sie her
    bekomme? Ich bedanke mich im Voraus für eure Antworte.
    Gruß aus Köln Niehl
    Markus
    Ja.:cool:
    das ist schön, auch als 4.20 gcd für mich ??????
    Beim Downgrade wird ein Gerätereset durchgeführt - daher vorher die Profile sichern oder umbenennen um die Arbeit der Neueinstellung zu sparen.
    Die FW kannst du doch einfach bei Garmin laden?
    4.49b:
    https://buy.garmin.com/shop/store/downloadsDetails.jsp?id=4743&product=010-00697-11&cID=145&pID=26876
    4.20:
    Download - Pfad:
    -> x50 Modelle
    http://www8.garmin.com/software/Oregonx50_WebUpdater__450.gcd
    (im Pfad gewünschte FW Versionsnummer anpassen)
    Schritte Update manuell:
    -in Oregon Verzeichnis :\GARMIN kopieren
    -umbenennen in ” gupdate.gcd ”
    -Oregon aus und wieder einschalten
    Offensichtlich ist die alte v4,20 aber mitlerweile vom Server entfernt worden. Dann musst du sie dir zumailen lassen wenn du ich selbst dran gedacht hast eine Sicherheitskopie zu machen.
    Ich denke aber die v4,49b ist die bessere Version.
    Evt. sendest du deine Email als PM - Dateigröße gepackt ca. 3MB
