OREGON x50 Firmware v5.10 - NEU - 12.10.2011
Webupdater oder manuell:
http://www8.garmin.com/software/Oregonx50_WebUpdater__510.gcd
Changes made from version 5.00 to 5.10:
-Improvements to the geocaching experience. See TrailTech (http://garmin.blogs.com/softwareupdates/2011/09/improved-geocaching.html) for more information.
-Fixed a potential hang on startup when importing large numbers of waypoints, tracks, routes, or geocaches
-Fixed issue with very long geocache descriptions
-Fixed shutdown when reviewing certain geocache descriptions
-Fixed issue where the photo orientation would be incorrect in the photo viewer
-Fixed potential shutdown while scrolling through Garmin Connect photos
-Fixed issue where some auto-archived tracks would be named in English regardless of user language
-Fixed bug that could cause some geocaches to not import
IMPORTANT: if upgrading from a software version less than 4.80 you must follow these steps for future BaseCamp Compatibility:If you are a user of BaseCamp now, or plan to be in the future, you must follow these steps to ensure your data is protected during this software update:
1 Connect your handheld unit to a computer and launch BaseCamp. Transfer all tracks, routes and waypoints to BaseCamp.
2 Delete the /Garmin/GPX folder from the handheld's mass storage.
3 Update the handheld's software via WebUpdater and reboot the handheld.
4 Reconnect the handheld to a computer and transfer your data from BaseCamp back to the handheld.
    Servus aus Bayern,
    wieso gibts denn keine Beta-Versionen mehr?
    Dann wär man wenigstens nicht über solche Fehler und Fehlfunktionen überrascht.
    So muß man nach jedem neuen Update erstmal tagelang das Forum beobachten, was diesmal wieder falsch läuft und ein Update überhaupt sinnvoll ist.
    Danke an die, die trotzdem noch die neuen Updates testen und die Bugs aufdecken.
    Grüße Jürgen
  • Moin,
    über die Startzeit kann ich nicht meckern, es sind wirklich nur wenige Sekunden mehr.
    na ja, das Ladeverhalten in der Version 5.10 ist stark abhängig vom Umfang der im GPX-Ordner abgelegten Daten. Bei einem größeren Umfang ist die Verzögerung gegenüber der Version 5.0 mehr als deutlich spürbar und damit eine eindeutige Verschlechterung!
    mfg
    - horst -
    Speziell bei Geocachern ist es nicht unüblich, dass man mehrere Tausend Caches (= Wegpunkte plus Beschreibungen und Zusatzinfos) auf das Garmin lädt. Dazu kommen üblicherweise eigene POI-Datenbanken mit zusätzlichen Punkten (z.B. bereits gefundene, selbst gelegte oder aktuell deaktive Caches), sowie häufig sehr vielen integrierten (Spoiler-)Bildern (via POILoader). Dazu evtl. noch verschiedene Karten (z.B. versch. OSM, Garmin Topo, Garmin City Navigator). Genau deswegen setzt man ja Oregon Geräte ein (weil die das alles können).
    In diesem Einsatzszenario kann die Ladezeit nach dem Einschalten aber mittlerweile jedesmal mehrere Minuten dauern (zuvor, d.h. bis FW 5.00, war das nur der Fall, wenn neue Datenbanken erstmalig geladen wurden). Damit wird mittlerweile das Gerät unterwegs in bestimmten Fällen zur Qual!
    Viele Grüße
    Mario
