Neue Firmware Version 11.25
Die letzte Beta ist auch die akutelle Firmware Version
https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-7-series/323444/fenix-7-series-system-software-11-25
Change Log
Added support for Primary Wearable and Primary Training Device (unified Training Status).
Added support and compatibility for the Outdoor Maps+ Subscription. This can be found in Map Manager, or purchased here: https://www.garmin.com/outdoormaps
Added Jet Lag Adviser to Fenix 7, 7S, 7X, Enduro2, Quatix, Tactix 7, and Epix Gen 2.
Added improved Backcountry Ski and Snowboard activities to automatically detect climbs, descents, and transition time.
Added wakesport activities, including wakesurf, wakeboard, water ski, and tube, to the list of available activities.
Added the sail expedition activity to the list of available activities.
Added sunrise/sunset app improvements, which includes a map of the sun's position, sun altitude graph, and almanac information to the sunrise and sunset glance.
Added support for Connect IQ System 6.
Added Distance to Start data field to the Sail Race activity on the Regatta Timer page.
Added 'Map Only' Touch setting to activities.
Added multi code point emoji support.
Added PacePro strategy page to Race widget.
Added Race Day card to Morning Report.
Added Stamina data field to Bike sports.
Added unspecified gender support.
Fixed an issue where the device was exiting battery saver when accessing the activity list multiple times in a row.
Fixed an issue with day of week labels on the active calories graph.
Fixed blank Connect IQ glances when using 4 or more.
Fixed golf plays like icon display issue.
Fixed heart rate graph color inconsistency in post activity summary.
Fixed HRV overlap in Morning Report in some languages.
Fixed incorrect page being pushed during indoor biking activities.
Fixed incorrect targets for Cycling anaerobic Daily Suggested Workouts.
Fixed intermittent shutdowns when connected to some phones.
Fixed issue causing double tone sound when pressing a key.
Fixed issue causing no Lactate Threshold test in Track Run.
Fixed issue causing Power Guides to show up as an option for runs.
Fixed issue where back swipes were not exiting Connect IQ apps.
Fixed issue where daily suggested workouts were not prompting again after ending a coach workout.
Fixed issue where palm touch could cause a shutdown when first used on a CIQ widget and then later trying to open a native widget.
Fixed issue where strength reps display could show an incorrect value.
Fixed issue where vibration could remain stuck on when using touch on the radial keyboard.
Fixed issue with Daily Suggested Workouts for long rides in Morning Report.
Fixed issue with emergency contacts.
Fixed issue with golf auto shot detection.
Fixed issue with map not showing all selectable points in some areas.
Fixed issue with the golf par value not showing correctly in Thai.
Fixed issue with the Race Calendar when multiple races are present.
Fixed missing heart rate chart in activity after having paired an RCT 715.
Fixed potential issue causing a sleep score of 0.
Fixed potential issue with sleep tracking.
Fixed potential issue with the save location feature not populating a valid position.
Fixed potential issues with running power graph and gauge.
Fixed potential shutdown in sleep window edit after having received a smart notification.
Fixed potential shutdown in Strength activity.
Fixed potential shutdown in XC Skate Skiing activity when trying to start the activity and using HRM Pro+.
Fixed potential shutdown when accessing the SOS flashlight feature.
Fixed potential shutdown when launching a strength workout.
Fixed potential shutdown when pausing training from the Daily Suggested Workout prompt.
Fixed potential shutdowns starting or during an activity.
Fixed Race Day morning report 'time until event' text.
Fixed Shimano STEPS ebike not showing up in search.
Fixed shutdown when entering 'edit mode' via press and hold on a graphical data field.
Fixed stocks app search not returning symbols that don't have exchanges.
Improved the Anchor app by adding a map page, anchor waypoint, and circle representing the drift radius.
Improved the Ultra Run 'Auto Rest' UI and performance.
Update Stocks Color for Thailand and Singapore.
Updated translations.
