Fenix 6 Series - 19.20
Zitat von Jeff_Odsweng
Hello Fenix 6 customers,
We understand this post of 19.20 is in reverse of what we usually do, but nevertheless, we didn't want to miss an opportunity to post the public release candidate, which is now rolling out to 20% of users. We know many are eager to begin using this update. Enjoy!
Please ensure that you are downloading the correct beta software for your specific device.
Instructions for installation are available below the change log on eac
Instructions for installation are available below the change log on each of the above pages.
19.20 Change Log Notes:
• New Adventure Race activity: This new activity prevents use of GPS data fields for navigation, allowing the watch to be used in adventure racing and orienteering races where GPS devices are not allowed.
• Added new workout animations which can be updated with Express or a Wifi sync.
• Added the ability to rate the perceived effort and feel of a Run, Bike, or Swim activity. The prompts appear during activity save. Go to [Activity] Settings > Self Evaluation for options.
• Added sleep tracking widget with sleep score and insights by Firstbeat AnalyticsTM.
• Added metabolic calories into the total calories reported in the calories data field and recorded in the activity file.
• Added setting to enable/disable workout audio prompts.
• Automatically disable Battery Saver when battery sufficiently charged.
• Updated workout audio prompts for hundredths distance precision.
• Updated Intensity Minutes determinations to align with guidance from CDC.
• Improved feedback on stress level readings.
• Improved calorie calculations for activities using a power meter.
• Improved results for daily Body Battery calculations.
• Improved visibility of Climb Pro alert page.
• Improved power meter calibration and settings.
• Improved Body Battery estimation when the device is powered off for a long period of time.
• Fixed issue where compass would become unresponsive during SUP activities.
• Fixed issue with manual time setup during initial setup.
• Fixed display issues when editing data field layouts.
• Fixed issue where recovery sets would not be properly displayed during workouts.
• Fixed issue where a Suggested Workout could draw with a nearly blank diagram.
• Fixed issue with editing data screens for Ultra Run app.
• Fixed text truncation issues when calibrating altimeter or barometer for some languages.
• Fixed issue with default FTP value for XC Ski.
• Fixed issue with distance to green layout while using 'Big Numbers' mode in golf activity profile.
• Fixed potential device shutdown while using ClimbPro.
• Fixed an issue where some training metrics were not updated after downloading stored heart rate from a capable chest strap.
• Fixed issue where the LAP key may not advance workout step.
• Fixed issue where Treadmill distance/pace would not record if watch was also connected to another nearby training device.
• Connect IQ improvements and bug fixes.
• Other minor improvements and bug fixes.
GPS: 5.30
Sensor Hub: 11.01
ANT/BLE/BT (Pro models): 6.11
ANT/BLE (non-Pro models): 3.00
Wi-Fi (Pro models only): 2.60
Please note, the updates released on these forums are not compatible for APAC region devices.
  • Das ist eine Finale Version, die Du schon vorab selbst laden kannst, wenn Du magst. Wenn nicht, wartest Du einfach. Das Update kommt auch noch per Express.
  • Ich habe ein automatisches Update über Bluetooth-Synchronisierung bekommen. Danach war die Uhr auf Version 19.20, aber GPS weiter auf 5.0.
    Ich habe mir das Update dann nochmal runtergeladen und manuell installiert. Danach war dann GPS auf Version 5.3
  • bei mir kam heute "offiziell" das update rein. ich habe dann nach dem "normalen" reboot des updates noch einen manuellen restart (power-on-knopf drücken bis zum abschalten) und dann wurden bei mir noch die sensoren upgedatet.
    anschliessender test der installation zeigte gps 5.30 an.
    vielleicht breaucht es einfach nur eien 2. restart, damit alles upgedatet wird ;-)
    wer weiss das schon
  • Bin jetzt mal längere Zeit (länger im Sinne von Zeit, nicht im Sinne von Strecke) gelaufen mit der 19.20. Direkt vor dem Lauf kam ein GPS-Update, wahrscheinlich das zuvor irgendwie gescheiterte auf 5.30 - jedenfalls wird jetzt .530 angezeigt. Bin einer Strecke nachgelaufen.
    Zwei Fehler habe ich entdeckt:
    - 2x zeigte mir die Anwendung "Zurück auf der Spur" (oder so ähnlich) an, meine Route wurde aber "versetzt" zur Soll-Route angezeigt.
      So, als läuft man quasi 100m westlich der Soll-Route. Wechsel auf's Höhenprofil und dann zurück auf die Karte hat das Problem halbwegs
      korrigiert. Wenn man sich später die Aktivität anschaut, dann gibt es bei der Strecke "Sprünge" und in den "Kurven unten" fehlen die Passagen.
      In etwa so, als hätte man STOPP gedrückt gehabt. Die "Zeiten" fehlen auch bei der Gesamtlaufzeit. Eventuell war ich einfach zu langsam?
    - Das Höhenprofil war "irgendwann" versaut als ich obigen Korrekturversuch erstmal durchgeführt habe. Meine Tour begann im Tal, hatte dann
      einen Buckel und endete wieder im Tal. Normalerweise sehe ich eine blaue Silhouette, die von links nach rechts zusehends grün wird. Nach
      dem "Versauen" sah der noch noch gelaufene Teil OK aus, der bereits gelaufene Teil war komplett waagerecht. Das hat sich nicht mehr
      "gefangen" bis zum Ende der Tour
    Schade!
  • Wenn ich Aufzeichnung während einer Streckennavigation stoppe um sie später fortzusetzen oder die Fenix6 mittels Autostopp stoppt so ist das Höhenprofil danach ein waagerechter Stich. Die Auf/AB Höhenmeter sind in dieser grafischen Ansicht dann auch eingefroren. Ist das  works as designed? War in früheren Versionen auch so.
  • Also beim biken funktioniert das mit dem Autostop und dem Höhenprofil.
    Ich habe auch immer Autostop aktiviert, damit die Zeit nicht weiterläuft wenn ich jemand zum quatschen treffe.
  • Dann probiere mal bitte mit später fortsetzen. Da habe ich den Effekt immer.
