Zitat von "odsweng"
Hello Fenix 6 customers,
We have new software available for your upcoming adventures!
*Our 9.92 Beta for Pro models contained ANT/BLE software version 6.03, however, we believe this peripheral software update has includes a bug that could lead to phone connection problems, or disconnects from sensors/headphones. The 9.94 and 9.95 update folders contain the file needed to backdate the ANT/BLE software from 6.03 to 5.04, which we recommend that you install if you have a Pro model. The instructions for installation provided on the above links remain the same, no additional steps are needed for installing the backdate file.
Please ensure that you are downloading the correct beta software for your specific device.
Fenix 6s: https://www8.garmin.com/support/download_details.jsp?id=15166
Fenix 6s Pro: https://www8.garmin.com/support/download_details.jsp?id=15164
Fenix 6: https://www8.garmin.com/support/download_details.jsp?id=15162
Fenix 6 Pro: https://www8.garmin.com/support/download_details.jsp?id=15160
Fenix 6x Pro: https://www8.garmin.com/support/download_details.jsp?id=15168
Instructions for installation are available below the change log on each of the above pages.
9.95 Change Log Notes:
- Fixed an issue with repeat and skip functions when using Spotify.
- Fixed an issue where playlists with Cyrillic characters would not display correctly on device.
- Fixed an issue where sensor icons were being displayed in the status bar even when disabled using a power mode.
- Fixed an intermittent issue where 'Around Me' search would not complete.
- Improved the visibility for Dogtrack by allowing one to pair to it through the sensors menu and automatically removing the widget once the sensor is removed.
- Made a couple of improvements for golf.
- Updated the UI for Body Battery and Training Status widgets.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 4.40
Sensor Hub: 7.11
ANT/BLE/BT (Pro models): 5.04 *See note above
ANT/BLE (non-Pro models): 2.11
Wi-Fi (Pro models only): 2.60
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the Fenix 6 Series you have in the subject line.
