Fenix 5 Update 3.30
Offiziell draußen ohne beta.
Changes made from version 2.90 to 3.30:
Added support for managing automatic software updates (Settings > System > Software Update > Auto Update). Setting Auto Update to 'Off' will disable downloads of software updates using Garmin Connect Mobile and Wi-Fi.
Added support for hiding the distance to next field, shown by default on the map page while navigating. (Settings > Navigation > Data Screens > Map > Data Field)
Added support for viewing navigation data pages on the Head Mounted Display (HMD).
Improved the power controls menu and introduced a 'disabled' state for connected features like Find My Phone, Music Controls etc. These applications will no longer disappear from the power controls menu, when the user has lost connection to the Garmin Connect Mobile App.
Added support for managing unit settings for pressure, altimeter and temperature from corresponding widget settings menu.
Improved the reliability of LiveTrack.
Improved the responsiveness of steps auto-goal.
Improved the activity settings menu by hiding GPS specific settings when GPS is turned off.
Fixed an issue where coordinate entry was not working correctly for Russian and Hungarian.
Fixed an issue, where the watch would incorrectly report that GPS signal was lost, while using UltraTrac.
Fixed a potential issue where the currently selected watch face may change after a software update.
Fixed an issue where the device could crash when applying a FaceIt watch face from the Garmin Connect Mobile App.
Fixed an issue, where the option to 'Copy Activity' was present in the main menu for non-copyable apps like Golf.
Fixed an issue, where the unit would crash when creating a custom alert for a new 'Other' app.
Fixed an issue, where the virtual partner fields, 'Time Ahead' and 'Time Behind' won't update during an activity.
Fixed an issue, where an empty elevation plot was being displayed during activity review for apps like, 'Rowing', which doesn't record elevation data.
Fixed an issue, where the device was calculating VO2 max for activities using UltraTrac.
  • Also ich habe seit dem Update auf 3.30 auch keinerlei Probleme mit den Watch Faces. Bei mir läuft auch "GearMin" auch völlig problemlos, auch nach dem Aufzeichnen von Aktivitäten. Bei mir allerdings nur laufen
  • Na Prima Garmin.
    SW 3.30 Fenix5X
    Heute Morgen wurde Karten (ich glaube Pazifik und Afrika) angeboten. Habe ich dummerweise geladen. Danach habe ich den gleichen Mist wie andere User. Karte friert ein, zeigt weisse Stellen. Zoomen geht natürlich auch nicht mehr, weil keine höhere Auflösung nachgeladen wird.
    So ist die Uhr für meine Anwendungen unbrauchbar. Kommt Abhilfe oder wie gehts weiter?
    P.S. Habe gerade festgestellt, das das Update auch Auswirkungen auf ein "fremdes" Watchface hat.
  • Ich glaube nicht, dass die runtergelaufenen Golfkarten die Kartenfehler produzieren. Falls Du irgendwelche IQ Datenfelder auf die Uhr geladen hast, lösche die mal bitte komplett von der Uhr und teste, ob der Fehler mit den Karten noch Auftritt.
    Golfkarten? Wahrscheinlich ein Schreibfehler, oder?!
    Hat es denn bei dir geholfen, IQ Datenfelder zu löschen?
  • Doch, ich meine das sind Golfplatzkarten.
    Heute das erste mal seit langem, dass ich kein "verschwinden" der Karte vom Display hatte. Hatte zuvor die installierten IQ Datenfelder komplett von der Uhr gelöscht. Mag Zufall gewesen sein, aber sonst habe ich erst einmal keine andere Erklärung dafür.
    Ich hatte heute auch mal die IQ Datenfelder entfernt und die Apps auf Werkseinstellungen gesetzt und dann funktionierte das auch mit der Karte. Scheinen also tatsächlich die IQ Datenfelder schuld dran zu sein. Ich hoffe Garmin bessert da bald nach...
    Ich denke ja eher, dass die Karten Coverage of North and South America und Pacific gemeint sind. Die waren nämlich (jedenfalls auch bei mir) eine Weile nicht mehr in Garmin Express verfügbar- oder sichtbar ...
    Thema IQ Datenfelder - dann sagt doch bitte einmal welche ihr entfernt habt. Vielleicht gibt es ja nur einen (oder wenige) 'Übeltäter' und man muss nicht alles löschen ... :cool:
    In der App hatte ich nur Graphical Heart Rate von Garmin konfiguriert. Bei mir hat herausnehmen des IQ Datenfeldes aber nicht gereicht, ich musste die App auf Werkseinstellungen zurücksetzen und ohne das IQ Datenfeld neu konfigurieren.
    Mal schauen, ob es mit der neuen Beta schon 'weg' ist ...
    Leider nicht !!
