Changes made from version 3.30 to 4.10:
Added support for Connect IQ 2.3.1 SDK. See the Connect IQ 2.3.1 SDK for a list of new features.
Added support for pre-defined Alarm labels. (Menu > Clock > Alarm Clock > Select an alarm > Label)
Added support for new VIRB remote commands.
Added support for adding widgets through the context menu. (Scroll to a widget > Menu Key)
Improved the VIRB widget to accurately reflect the settings available on the connected VIRB, which may vary with model.
Fixed an issue where the activity summary information for multisport profiles only represented data from the last leg.
Fixed an issue where the device screen seems to pulsate when using a white background, in low power mode.
Fixed an issue where ConnectIQ data fields were not able to record information to FIT files.
Fixed an issue where the HMD configuration won't match what is being displayed on device.
Fixed an issue where the device backlight would not work as expected when Do Not Disturb was enabled.
Fixed an issue where the 'Lap Ascent' field was not displaying valid data on the lap alert page.
Fixed an issue where the Indoor Row summary information was displaying distance metrics, instead of stroke data.
Fixed a potential issue where the device could freeze when dismissing multiple smart notifications.
Fixed a potential issue where the Training Effect value on post activity summary won't match the value shown on Garmin Connect.
Improved the consistency of routing results when using segments with courses.
Fixed an issue where the map wouldn't feel responsive when the user was off-course at the beginning of a navigation.
Fixed an issue where the distance remaining field would not update when using segments.
Fixed a potential issue where certain CIQ watchfaces could crash the device. (Requires Display 2.30)
Made various bug fixes and code improvements to improve stability.
http://www8.garmin.com/support/download_details.jsp?id=11429
