=== ALL MODELS: ===
• Fixed an issue where the multisport app names were blank on the last released public beta.
• Fixed an issue where the Barometer watch mode setting was not being applied correctly.
• Fixed an issue where the elevation value on the Ski data page did not match the system elevation units.
• Fixed an issue where the cog value could not be set to a value higher than 45, while setting up a Shimano Di2 Shifter.
• Fixed an issue where the device may not respond to button presses when using the lap key during a lap Swimming workout with Drill log disabled.
• Added support for Connect IQ SDK 2.3.2.
• Added support for adjusting the device backlight using the Controls menu.
• Added support for 'Flashlight'. This will be accessible from the System Hotkeys and the Controls menu.
• Improved the readability of long golf course names on device.
• Fixed an issue where the Music widget would timeout when playing music.
• Fixed an issue where one couldn't install up to 32 Connect IQ items through Express.
• Fixed an issue where the system menu wasn't accessible when using a Connect IQ item.
• Fixed an issue where the pace displayed on the segment page was not as smooth as the system pace.
• Fixed an issue where the device would crash when attempting to continue a paused golf round.
• Improved scaling on Heart Rate widget History screen
=== Fenix 5X only: ===
• Fixed an issue where POI's on the map and search lists were not translated correctly when the system language was set to Arabic.
• Fixed an issue where the map would not snap to the user's current location after panning to a distant location during an activity.
CHECK VERSIONS AFTER UPDATE: Settings ➠ System ➠ About
░░ Installation Instructions
• Download and unzip fenix_***Beta.zip
• Place the gupdate.gcd file found in the System_v*** folder in the \GARMIN directory
• Place the gupXXXX.gcd file found in the Sensor Hub_v*** folder in the \GARMIN\REMOTESW directory
• Place the gupXXXX.gcd file found in the Display_v*** folder in the \GARMIN\REMOTESW directory (if this file present: actually this time it's only for 5X).
• Place the gupXXXX.gcd file found in the GPS_v*** folder in the \GARMIN\REMOTESW directory.
• Place all files found in the Text_v*** folder in the \Garmin\TEXT directory
• Disconnect from your computer and proceed with the update.
░░ DOWNLOAD UPDATES ARCHIVES:
fenix 5X:
http://download.garmin.com/software/fenix5X_508Beta.zip
fenix 5:
http://download.garmin.com/software/fenix5_508Beta.zip
fenix 5S:
http://download.garmin.com/software/fenix5S_508Beta.zip
