Fenix 5x software 6 verfügbar
Change Log:
Added support for Rep Counting during Strength and Cardio workouts which can be created on Garmin Connect Web and Garmin Connect Mobile. To enable Rep Counting, ensure that Settings > Activities & Apps > Strength > Rep Counting is enabled. Start the timer to automatically count reps during sets. Press the lap key to rest between sets. You can edit the number of reps and weight for your last set during a rest period. Press the lap key to advance to the next set.
Added support for All-Day Stress. To view the Stress widget, hold the Up key from any widget and select Add Widget > Stress. You can view your current stress measurement on the widget page. Press the enter key to view a graph of your stress over the last four hours. Press Down to access the Four-Fold Breath relaxation timer.
Added support for setting up Wi-Fi Networks on device. After syncing with Garmin Express or Garmin Connect Mobile at least once, go to Settings > Wi-FI > Add Network to search for Wi-Fi networks. Select a network. If the network is secure, enter its password to join it.
Added support for manual calibration of the Barometer. (Settings > Sensors & Accessories > Barometer > Calibrate)
Added support for Hourly Alerts. (Settings > System > Time > Alerts > Hourly)
Improved device key handling while using Connect IQ apps.
Improved the course navigation icons for better visibility and contrast.
Fixed an issue causing Varia UT800 Smart Headlights to periodically disconnect or power off during a ride.
Fixed an issue causing the Running Dynamics Pod to disconnect when using Connect IQ Apps.
Fixed a potential issue preventing a course from being joined when not joining it at the start.
Fixed a potential issue causing Personal Records to be reported inaccurately.
Fixed an issue where the device would not transition to the climb screen while using Auto Climb in certain situations.
Fixed an issue where the sunrise and sunset alarms were not working as expected.
Fixed an issue where the elevation plot for a single activity in a multisport activity would display the elevation history of the entire activity.
Added support for configuring the track color of saved activities. (Settings > Map > Track Color)
Fixed an issue where certain artifacts were being drawn on the map page while panning or zooming.
Fixed an issue where the device might crash when editing settings for a multisport activity during a transition.
Fixed an issue where the map would not refresh course data if it was edited during active navigation.
Fixed a potential issue where the watch may appear frozen on the watchface, when exiting out early from an active course route calculation.
Fixed a potential issue preventing some Training Status data from being uploaded to Garmin Connect.
Note: There are language files and display update that is available to all users right away.
