Fenix 5X - 7.91 Public Beta
Fenix 5X: http://www8.garmin.com/support/download_details.jsp?id=11665
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
7.91 Change Log Notes:
•Added support for a Sunrise & Sunset widget. Settings > Widgets > Add Widgets > Sunrise & Sunset.
•Added support for an Alternate Time Zones Widget. Settings > Widgets > Add Widgets > Alt. time Zones.
•Added a setting to display a calibration prompt when using a power meter. When using a Vector, this will also allow the user to set the power meter crank length. Menu > Settings > Sensors & Accessories > Power Meter > Calibration Prompt.
•Fixed an issue where the altitude on device wasn't accurate when using the Jumpmaster app.
•Fixed an issue where Broadcasting Heart Rate was not working as expected, if accessed from the power controls menu.
•Fixed an issue where a ConnectIQ watchface would flash when downloaded using the Garmin Connect Mobile app and the device would revert back to a stock watchface.
•Fixed an issue where Flashlight would turn off when using gestures.
Please send all bug reports to [email][email protected][/email], and indicate which model of the fenix 5 series you have in the subject line.
Please note that the public beta's are intended for non-APAC devices only.
  • bin mal gespannt, ob sich beim Pulssensor was ändert. Berichte bitte
    Die Beta läuft ohne Probleme.
    Der Pulssensor hat im grossen und ganzen nur Nachts aussetzer und ich kann nicht ganz ausschliessen, dass es an mir liegt. Habe ich im anderen Thread näher beschrieben. Weil hier geht es ja um die Beta.
