Neue 3.70
Montana (WebUpdater) software version 3.70
Changes made from version 3.60 to 3.70:
Added new configurable data field options: Alarm Timer (from alarm clock page), Automotive Turn (lane assist), Avg. Lap, Compass Heading, Current Lap, Date, Elevation Above Ground, GPS Elevation, GPS Heading, Grade (must be moving), Lap Distance, Laps, Last Lap, Location of Destination, None (blank field), Stopwatch Timer, Total Lap, Track Distance (reset when current track is cleared), Vertical Dist. to Dest, Vertical Dist. to Next. See TrailTech (http://garmin.blogs.com/softwareupdates/2011/12/configurable-data-fields.html) for more information
Added data field categories
Added trip computer setup for additional configurability (this includes adding multiple trip computer pages)
Improved elevation data stored in track logs
Improved serial support
Improved Arabic keyboard
Improved display of configurable data fields in night mode
Fixed 3D View to rotate based on compass heading
Fixed issue where some auto-archived tracks would be named in English regardless of user language
Fixed issue with track log recording while using the stopwatch
Fixed issue that could cause some geocaches not to import
Fixed issue with entering the next stage of a geocache while the Routing Activity is set to Prompted
Fixed an issue that could occur while reviewing certain geocache descriptions
Fixed a potential hang on startup when importing large numbers of waypoints, tracks, routes, or geocaches
Fixed potential issue that could occur while reviewing certain photos
Fixed potential issue related to shortcuts and orientation change
Fixed potential issue related to setting custom background images
Fixed potential issue with entering a street number during an address search
Fixed issues with NMEA output using the AMPS Rugged Mount
Fixed issue with magnetic north offset when projecting a waypoint
    Salü
    das harzige Luftlinien Navigieren , dass die Distanz , plötzlich bei -20m hängen bleibt und dann auf +10M hoch hüpft scheint behoben zu sein,:)
    Zumindest empfinde ich dies so ,seit einem Test, bei dem ich zu einem 100m entfernten WP navigiert habe.
    Kann dass jemand bestätigen ?
    Gruss
  • Link zur Garminseite für den Download-Link.
    Da der Link zum Blog in #1 nicht funktioniert, hier noch einmal
    Configurable Data Fields ;)
    Salü
    Gruss
    Sollte das zutreffen, mach ich drei Kreuze!!!
    Werde in Kürze ausgiebig testen und berichten...
    Weihnachtsgrüße
  • Salü
    Leider nein - war heute bei 14 Dosen und hatte immer wieder dieses Phänomen des systematischen Einkreisens... 15m vor, 25 zurück.
    Bei mir hat es heute sehr gut geklappt mit der Annäherung. Das Montana führte mich immer ohne Verzögerung zu den Zielkoordinaten. Vielleicht lag dies aber auch an den perfekten Wetterbedingungen und am offenen Gelände. Wenn das nun so stabil bleibt, bin ich sehr zufrieden.
    Salü
    Heute nur 2 Dosen
    Nr1 im Freien , kein systematisches Einkreisen ausser den bekannten 2 m rechts links vorne zurück , aber OHNE hängen bleiben, immer brav Cuntdown 5,,4,,3m,2m, 1,m .
    N2: Am Waldrand, bis 2m vor den Cache kein Einkreisen, dan ein Sprung auf 15 m , was ich aber auf die Annäherung an den Wald zurück führte( vedeckte Sicht). 10m am Cache vorbei dann aber wieder Punktgenau er Countdown ( 9m 8mm 7m 6m 3m,,,,)zum Ziel.
    Meinungen anderer Montana User?
    Gruss
  • Konkret vorhin nochmal:
    GPS navigiert beim Wegpunkt bei
    48°08.836N 11°37.722E
    zu
    48°8.836N 11°37.705E
    und zeigt dort bei 4m GPS Genauigkeit 2m zum Ziel.
    Durch Abklopfen der Möglichkeiten dann bei
    48°8.835N 11°37.725E
    fündig geworden - da zeigt das Gerät bei 4m Genauigkeit 0m zum Ziel.
    Das sind 25m Strecke, auf der das Gerät meinte, daß ich mein Ziel schon erreicht hätte.
    Ich habe vor zwei Tagen 3.70 eingespielt und seit dem Probleme mit Einschalten.
    Immer wen ich das Gerät vom USB nehme lässt sich das Gerät nicht einschalten.
    Ich entferne dann für 2 Sekunden den Accu. Danach kann ich einschalten.
    Ich muss den Einschaltknopf meiner Meinung nach etliches länger drücken bis sich etwas tut.
    Haben Andere die gleichen "Erlebnisse"?
  • Ich habe vor zwei Tagen 3.70 eingespielt und seit dem Probleme mit Einschalten.
    Kann ich nicht bestätigen. Habe eben wieder einige Daten für den anstehenden Urlaub auf das Gerät kopiert und es startet auch damit wie immer normal.
    Dein Problem kommt mir aber bekannt vor. AFAIK hat jemand im US-Groundspeak-Forum von dem gleichen Problem geschrieben.
    Negativ!
    Auch bei mir alles wie immer - zumindest was diesen Punkt betrifft. USB, Datenübertragung, Ein- und Ausschalten ohne Probleme und Hänger.
    Zum Testen des "Einkreisverhaltens" kam ich noch nicht.
    Grüße
