Firmware 6.27BETA
hange History
Changes made from version 6.24 to 6.27:
Added Steps widget (Settings > Widgets). Note: Steps replaces the previous Wellness widget
Added My Day widget (Settings > Widgets)
Added Golf widget (Settings > Widgets)
Added Last Run widget (Settings > Widgets)
Added Last Ride widget (Settings > Widgets)
Added Last Swim (Settings > Widgets)
Added Last Sport widget (Settings > Widgets)
Added Calories widget (Settings > Widgets)
Added support for Jumpmaster App (Settings > Apps > Add New)
Added support for Tactical App (Settings > Apps > Add New)
Added new Digital watch face Layout option (showing step goal progress and move bar)Added new Digital watch face Seconds Style (Requires Display update 2.95)
Added Do Not Disturb feature (press & hold LIGHT)
Added support for golf scorecard uploads
http://www8.garmin.com/support/download_details.jsp?id=9504
Nicht aufgeführt ist, dass die App "stress score", "Lactate Threshold" in Gesamtwerte und das Datenfeld "performance condition" neu ist.
    schaut mal unter protokolle bei laufen nach, da werden nur striche angezeigt.
    man kann die aktivität aber laden
    If you choose to update to beta software release 6.27, you'll will observe that the daily activity list in your device history is now dashes. The .FIT file is impacted in no way and can still be accessed from the history on your device, or uploaded to Garmin Connect. All new activities created using 6.27 will not be impacted by this bug. They will appear as normal. We would also like to point out that this does not actually impact your activities. It's simply a surface issue in how the information on that page is written, nothing more. To recover this, you can remove all activities from your device and then add them back to the \Garmin\Activity folder of your Fenix 3. You'll then see that the issue is corrected. We chose to move forward with this beta release even though this bug is present. We felt that the new additions outweighed the low impact the activities transcription has on the user. We trust you'll feel the same way. Enjoy the additions!
    (">Quelle">Quelle)
    Hi, bedeutet das, dass man den Schlafmodus nicht mehr manuell einschalten kann?
    Genau. :-(
    In mehreren Etappen zu schlafen ist bei Garmin nicht vorgesehen, Bei Garmin werden 8h am Stück geschlafen. Sonst erfüllst du dein Soll nicht.
    Haha. :D
    (">Quelle">Quelle)
    okay, danke für den link. die neue aktivität wird tatsächlich richtig angezeigt .
    dafür bin ich heute 55min gelaufen und die uhr hat mir keinen neuen VO2 ausgeworfen.
    da steht immer noch ich soll 10min laufen gehen:confused:
    Dann noch eine Frage, weiß jemand was das Datenfeld Perfom.Cond. zu bedeuten hat? Während der Aktivität wurde mir da nur ein schwarzer Bildschirm angezeigt.
  • Genau. :-(
    Hoffentlich bringt Garmin das nicht in die offizielle Version.
    Manuelles einschalten des Schalfmodus hat bei mir immer super geklappt.
    Das wünsche ich mir auch. Die die lieber Automatik nehmen, können das ja weiterhin tun. Und die, die (aus Gründen) das lieber manuell machen, wären auch bedient.
  • App "stress score", "Lactate Threshold" in Gesamtwerte und das Datenfeld "performance condition" neu ist.
    Krass was Garmin in den betas alles neu reinpackt. Ich hoffe das diese Funktionen auch schnell in den normalen Firmware Updates drin sind.
    Was sind den die 3 genannten Sachen, was machen die :D
  • Hoffentlich bringt Garmin das nicht in die offizielle Version.
    Vielleicht geht's mit der neuen Option "Nicht stören" ( Ein/Aus gedrückt halten).
    Nope.
  • Hat die 6.27 kein deutsches Sprachpaket mehr? Kann unter Sprachen nur English auswählen :confused:
    Ok, selbst gefunden. Musste neu installiert werden über Express
