Firmware 7.00
Change History
Changes made from version 6.90 to 7.00:
-Added support for CIQ SDK 1.2.6.
-Added support for Achievements. (Summary of personal records available after an activity is saved, and while still on the saved activity summary page.)
-Added support to turn off activity monitoring Goal Alerts. (Settings > Activity Monitoring > Goal Alert)
-Added support for post activity download of Heart Rate data from HRM-Tri and HRM-Swim sensors. (History > Activity > Download Heart Rate)
-Added support to calibrate altimeter at extreme altitudes.
-Added floors climbed history to the steps widget.
-Added the heading bug to the elevation plot page.
-Added support for saving a waypoint from the Dual Grid page.
-Added support for displaying status of GPS EPO data to the About page. (Settings > System > About > Scroll to the EPO Status Page, Note: downloaded EPO data will not always be stored on the device file system)
-Added support for viewing more than 100 Saved Locations on the device.
-Added support for Walk App (Settings > Apps > Walk).
-Added support for Swimrun App (Settings > Apps > Swimrun).
-Added additional backlight settings: a 4 second timeout and a 5% backlight level.
-Improved distance scrolling on the Project Waypoint page.
-Improved Bluetooth to phone connection reliability. (Requires BLE/ANT FW 3.50)
-Improved auto zoom during waypoint navigation.
-Improved the readability of golf course names on the golf course list page.
-Improved accuracy of floors climbed data
-Fixed a potential issue where Intensity Minutes were not being calculated correctly for devices paired with a Heart Rate sensor.
-Fixed an issue where the Auto Scroll setting was not available for paddle sports activity profiles.
-Fixed a potential issue with Timer alarms not working as expected if Do Not Disturb was enabled.
-Fixed a potential issue where the device could crash when saving a swim activity with HRM Tri data.
    Dieses Display stimmt aber so. Schwarz ist es nur wenn noch Strom drauf ist(Uhr sich aufhängt etc)
    also bei meiner ist einfach ganz Schwarz wenn aus.
    liegt bei mir schon immer bei ca 2% pro tag. seit version 2.9 -- hoffentlich bleibts auch so.
    im grossen und ganzen immer schon die gleichen optionen eingestellt.
    aktuell eingestellt:
    widgets - abc, baro, letzte aktiv., benachrichtigungen, sun/moon, battery
    bluetooth, gps , glonass = on
    beleuchtung durch bewegung 4sec, 20%
    bei aktivitäten, wie bergsport, rad, ski -- dauer zwischen 2 bis 4 std sind so 15 - 25% weg.
    verbrauch scheint was sehr gerätespezifisches zu sein.
    lg
    Du hast recht, lag falsch, Edge und Vivosmart HR wird Weiss, Fenix ist schwarz :o
    LG
  • Heute 36800 Kalorien verbraucht.... Geht doch.
    Seit der 7er Version funktioniert so einiges nicht richtig.
    Notification ist nur auf Englisch.
    Früher kam "verwerfen" jetzt subtile oder so.
    Habe ein Android Note 4 mit 6.01
    Servus
    Habe heute einen relativ lockeren Trainingstag gehabt - noch sehr gebremst wegen Triestmarathon am vergangenen Sonntag
    10km Hunde spazieren
    20km Radrolle Daum
    6,5 Grundlagenlaufeinheit Laufen
    3,2km Rudern auf Rudermaschine
    Gesamt 3063 Kalorien - wenn's stimmt (wenn's bei meinem Vorschreiber über 30.000 anzeigt - was war da der Umfang;=)))))))) wobei ich diese ganzen Ziffern nicht ernst nehme, nach gut 20 Jahren habe ich meinen Verbrauch eher schon im Gefühl und ganz untrüglich ist die Waage ;=)) wobei hier natürlich die Flüssigkeit(Defizit oder Überhang) zum einplanen ist
    Beim Ironman vor langer Zeit habe ich ungefähr 10.000Kalorien verbraucht - also wärs ein Dreifacher, geht sich aber in einem Tag nicht ganz aus ;=)))
    danke euch allen für Euer Feedback. Ich finde das wichtig, dass wir uns hier austauschen, lese regelmäßig, gerade vor Updates, das Forum. Mit 7.0 scheint ja wieder einiges im Argen... Ich warte lieber, zumal nächste Woche Marathon ist und die Uhr da "laufen" muss.
    Weiter so und Grüße von Elba
  • Also seitdem ich diese Version drauf geladen habe, zählt die Uhr die Stockwerke sehr unregelmäßig und eigentlich immer zuwenig.
    Was sind da eure Feststellungen?
    Stockwerke - also wenn ich im Rahmen einer Laufeinheit 450hm mache, für ein Stockwerk 3m einsetze, dann müsste ich 150 Stockwerke gemacht haben, bei 4m gut 110 - nö - aber so ganz habe ich den Stockwerkssinn sowieso nicht verstanden - wenn ich einem meiner Laufkollegen erzähle ich bin 110 Stockwerke hoch gelaufen dann lässt er mich einliefern ;=)))))))))))))
    Kann ich bestätigen. Hängt aber meiner Meinung nach mit dem "Losbrechmoment" des Schrittzählers zusammen.
    Gruß Benny
    Kann ich auch bestätigen....
