Firmware 7.20BETA
Change History
Changes made from version 7.13 to 7.20:
-Fixed a potential issue with swim workouts, when the rest interval is the final step of the said workout.
http://www8.garmin.com/support/download_details.jsp?id=9504
  • 1. Place the gupdate.rgn file in the ‘GARMIN’ directory
    2. Place the gup1909.bin and gup2051.bin files in the GARMIN\REMOTESW directory
    3. Disconnect from computer
    was willst du uns jetzt damit sagen?
    das ist doch oft das Standartprocedere.....
  • Bluetooth ist jetzt 3.6. Ab dieser Version? Bin mir da nicht sicher. Ich finde Bluetooth Ein/Ausschalten nicht mehr. Nur Koppeln ? Bin ich neben der Spur, oder ein Fehler?
  • ist da wo es auch bisher war.
    Einstellungen - Bluetooth - Status.
    Ich habe diese Funktion auf einem Hotkey liegen und der tut noch was er soll.
    Gruß
  • Im englischen Forum ist ein umfangreicheres Chane Log.
    7.20b Change Log Notes:
    -Added support for accessing other data screens while in a swim workout rest interval.
    -Improved accuracy of distance and lap counting for Pool Swim.
    -Improved Auto Lock behavior to avoid locking while in use.
    -Improved the reliability of foot pod calibration.
    -Improved ETA and ETE estimates when navigating a course.
    -Improved label and background consistency across all widgets.
    -Fixed an issue where Project Waypoint was not using the system setting for bearing units. (Settings > Sensors > Compass > Display)
    -Fixed a potential issue where VO2 Max and Lactate Threshold estimates were being used incorrectly with Trail Run activities.
    -Fixed an issue where distance data fields for SUP were using incorrect precision and units.
    -Fixed a potential issue with high battery drain in watch mode.
    -Fixed a potential issue where the user was not given a warning alert on the last length of a swim workout.
    -Fixed a potential issue where certain multisport profiles were not available in the app list when navigating a course.
    -Fixed potential BLE/ANT communication issues. (Requires BLE/ANT update 3.60)
    -Fixed a potential display issue with one of the analog watch faces. (Requires Display update 3.50)
    -Fixed a potential issue with wrist HR failing to update. (Requires WHR update 2.60)
    Das ist wohl nur etwas mehr als die (grobe) Zusammenfassung der letzten Betas. Display und Ble/ANT sind tatsächlich neu.
    Die 7.20 wird wohl bald offiziell.
  • Ich kann Bluetooth auch auf Hotkey legen. Aber da kommt auch nur die Option Koppeln. Status Ein/Aus ist bei mir weg...Auch das Bluetooth Symbol auf dem Display ist natürlich nicht da.
  • vielleicht installierst die SW noch einmal darüber.
    Ich habe definitiv 7.20 Anzeige 3.50 BLE 3.60 und noch die Möglichkeit BT ein- und auszuschalten.
    Danke. Habe ich erneut aufgespielt. Unveränderter Zustand. Anzeige wie bei Dir. Ich lass das jetzt so... irgendwann gibt es ja was neues....
  • Leider wieder kein Support für Crosstraining.
    wenn irgend ein Menüpunkt fehlt.... Hardreset durchführen.#!!!
    Wenn dann immer noch dieser nicht angezeigt wird dann den Support anrufen, ggf einschicken!
