Hier der Link:
http://www8.garmin.com/support/download_details.jsp?id=9504
Changes made from version 8.35 to 8.36:
•Fixed an issue where the Baro trend line would stop updating.
•Fixed an issue where the last hour of the hourly forecast data was always invalid.
Installation Instructions
1.Connect your fenix 3/tactix Bravo/quatix 3 to your computer using the USB cable. Download and unzip fenix3_tactixBravo_quatix3_***Beta.zip.
2.Place the GUPDATE.RGN file, found in the ***_Beta folder, into the \GARMIN directory of the device.
3.Place the GUP2051.BIN file, found in the ***_Beta folder, into the \GARMIN\REMOTESW directory of the device.
4.Disconnect from your computer and proceed through the update.
5.If you would like to revert to the last public release software, follow the above steps, but place the gupdate_830.rgn file into the \GARMIN folder of the device. Rename the file to gupdate.rgn before disconnecting your device. NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
