Firmware (8.40) 8.50 über Garmin Express
http://www8.garmin.com/support/download_details.jsp?id=7623
Use Garmin Express to install this file.
(2.09 MB)
View system requirements
Notes:
•WARNING: If this software is uploaded to a device other than that for which it is designed, you will not be able to operate that device.
•If attempts to upload software fail, you may need to return the device to Garmin® for service.
Change History
Changes made from version 8.30 to 8.40:
•Added support for persistent sensor history data. Altimeter, Barometer and Heart Rate history graphs should now retain data after power cycling the device. The barometer history data should also be retained while switching between different plot scales.
•Added support for communication with a VIRB 360. Also, added support for new VIRB remote commands like Sleep and Wakeup.
•Added support for logging Heart rate range information along with time in corresponding zones to activity FIT files, which allows for displaying this information on Garmin Connect Web.
•Fixed an issue where a failed WIFI sync after an activity could cause the Run Cadence to be invalid on the subsequent activity.
•Fixed an issue where a '?' was being displayed on the turn direction page while navigating a course.
•Fixed an issue where Total Descent on the Ski data page was not respecting the system elevation units.
•Fixed an issue where certain characters on the watchface were getting clipped for some languages.
•Fixed an issue where the month information on the watchface was using an incorrect glyph in Russian.
•Fixed an issue with executing custom interval bike workouts on device.
•Fixed an issue with the 'Distance per stroke' data field for paddle sports.
•Fixed an issue where the random seconds style for a digital watchface would only update for the top half of the screen. (Requires Display 3.70)
