Epix System software version 2.80 as of August 13, 2015
http://www8.garmin.com/support/download_details.jsp?id=9041
Changes made from version 2.70 to 2.80:
◦Added Course navigation mode (Settings > Navigation > Type). An HSI Compass will be utilized on the Guide data page when navigating in this mode
◦Added support for Smart Notification Actions (interact with the incoming notifications directly from the pop-up or within the Notifications widget, e.g. clear a message or reject an incoming call)
◦Added support for trails found in ActiveRouting cartography
◦Added magnetic variation compass setting ( Settings > Sensors > Compass > North Ref. > User )
◦Improved support of edited locations from BaseCamp
◦Improved city spell search
◦Improved pace in UltraTrac
◦Improved map drawing performance for long activities and courses
◦Improved track log for open water swim activities
◦Fixed potential issue when loading large custom map files
◦Fixed a potential issue with navigating courses
◦Fixed an issue with utilizing the setting for Swim Stroke Type Detection
◦Fixed issues with Hide/Show Track Log and Hide/Show User Locations map Settings
Download
http://download.garmin.com/software/EpixSystem_WebUpdater__280.gcd
oder
http://www.gawisp.com/perry/fenix_D2_tactix/EpixSystem_WebUpdater__280.gcd
Archiv für Downgrade oder Backups:
Up-Downgrade:
-FW File in Geräte Verzeichnis :\GARMIN\ kopieren
-umbenennen in ” gupdate.gcd ”
-GPS aus und wieder einschalten
(Achtung: alle persönlichen Einstellungen gehen verloren, ggf. vorher Profile sichern)
OLD FW
2.70 http://www.gawisp.com/perry/fenix_D2_tactix/EpixSystem_WebUpdater__270.gcd
2.50 http://www.gawisp.com/perry/fenix_D2_tactix/EpixSystem_WebUpdater__250.gcd
2.40 http://www.gawisp.com/perry/fenix_D2_tactix/EpixSystem_WebUpdater__240.gcd
2.30 http://www.gawisp.com/perry/fenix_D2_tactix/EpixSystem_WebUpdater__230.gcd
  • Hatte es auch gerade gesehen und im Naviboard eingestellt.
    Bei
    "Added support for trails found in ActiveRouting cartography"
    da bin ich ja mal gespannt.
    Zu finden unter:
    Kartenpunkte> Trails (ganz unten)
    aber irgendwie keine Angaben, wie lang der ggf. gewählte Active Routing Weg ist (also keine Details)...
    Wenn ich dann ein Ziel auf dem Weg ausgewählt habe und starte, schmiert mir die Kartenseite ab...
    Nachtrag:
    Nachtrag: wenn man einen SQL Trail auswählt, muss man noch ein Ziel auf der Karte setzen (etwas mühsam), dann berechnet die Epix u. U. mehrere Minuten die Route, da war ich beim Rumspielen zu schnell/ungeduldig und deshalb wohl die Abstürze.
  • Nun scheint auch das Löschen von WPs über Basecamp zu funktionieren. Die übertragene Route sah auch gut aus (gab ja bisher immer Murks (zu lang/Luftlinie zusätzlich eingebaut).
  • Die Aktivitätsfarbe lässt sich nach wie vor nicht ändern. Die Farbe bleibt immer noch Hellcyan, auch wenn etwas anderes eingestellt wird.
    Sonst (bis jetzt) keine Probleme mit den neuen FW 2.80
  • Wenn man eine Aktivität gestartet hat, klappt jetzt wohl auch das nachträgliche navigieren zu einem WP, ohne das man die Aktivität vorher beenden muss.
  • Nun klappt auch die Eingabe von Städtenamen für die Suche (city spell search). Wobei die das anscheinend wirklich nur für Städtenamensuche gefixt haben, für die anderen Kategorien funktioniert die spell search nachwievor nicht (jedenfalls bei mir).
    Nutzung von IQ DataFiels funktioniert immer noch nicht bzw. nur ungenügend.
    Epix stürtzt immer ab und bootet neu mit diesem Elevation Datenfeld:
    https://apps.garmin.com/en-US/apps/0bbabaa9-aedf-44e8-913b-60e4198be083
  • Ich glaube, dass die Apps etc. aus dem IQ Store fast immer irgendwie auf die aktuelle FW angepasst werden müssen, wenn das unterbleibt, kann es Probleme geben. Oder liege ich da falsch?
    Na ja, ich hab sowieso nichts mehr aus dem Store auf meiner Epix installiert...
    Hallo,
    mit der 2.80 kann ich die Epix jetzt endlich mal wirklich nutzen. Denn noch mit der 2.70 stürzte sie bei fast jeglicher Art von Navigation ab. Egal ob beim Laufen oder sogar beim Spazieren gehen starte sich die Epix regelmässig durch. Egal ob ich OSM Karten oder die Topo V7 Pro verwendete. Einzig die mitgelieferte Karte hielt machmal ein wenig länger durch... bis sie wieder die Grätsche machte.
    Gestern bin ich dann mit der 2.80 drauf und einer OSM Karte 60km Rad gefahren und kein einziges mal gab es einen Absturz. Auch mit Testweise auf 12m Auflösung eingestellt kein Absturz. Da kam die Uhr dann zwar nicht mehr ganz mit dem Bildaufbau nach und an Abbiegungen brauchte sie eine Zeit bis sie mich wieder eingeholt hatte, aber blieb stabil.
    Ich bin ja so froh... denn vorher war das einfach nur ein Krampf.
    Viele Grüsse, Thomas
    Seit dem Update auf 2.80 spielt der barometrische Höhenmesser verrückt. Die Werte stimmen überhaupt nicht das manuelle kalibrieren hilft nur vorübergehend - auf dem Widget wird nach wie vor die falsche Höhe angezeigt.
    Garmin wäre gefordert hier raschest Abhilfe zu schaffen.
    Habe heute bei einer kleinen Runde das Tracking eingeschaltet. Während dem Laufen habe ich über die routingfähige Karte eine WP gesetzt und mit 'Los' die Navigation zum Ziel gestartet.
    Die Uhr hat auch einen Routenvorschlag berechnet und mich zum Ziel geführt. Soweit alles wunderbar. Hatte bis jetzt auch keine 'Hänger' mehr.
    Bei der Ankunft habe ich dann den Track gestoppt und gespeichert. Wie schon bei der 2.70 bleibt die Route aber immer noch sichtbar und geht erst weg, wenn ein neues Tracking gestartet wird.
    Hier wurde noch keine Abhilfe geschaffen.
    Die Aktivitätsfarbe bleibt bei mir auch immer Hellcyan.
    Ansonsten habe ich aber nach dem kurzen Test das Gefühl, dass die Uhr stabiler läuft.
