I ran a 21k today. It was recorded in the garmin watch but did not sync in the app. I tried to manually upload the activity but indicated as "One of your file was not accepted by the system." Can someone help me how to fix this please
Try running it through FIT File Viewer—it works in the browser and can often fix corrupted files.
If you're still unable to import the activity into Garmin Connect, attach the file to this thread. We can take a look to see if it is repairable.
Hello, I have messaged a few different forums on here to get help correcting my invalid run on Garmin. I used Fit File Viewer and it converted into a file with nothing on it but then had individual files with my activity data. Sharing here: would appreciate your help so much. Thank you! https://drive.google.com/file/d/1J01YHf9C93Iqlyw1AVSMebI4PSBvPEl3/view?usp=sharing
When I try to open one it says "there is no application set to open this document"
macOS doesn’t have a native application to open .fit files. They’re not meant to be opened like documents; they’re activity data files for Garmin Connect and your Garmin device.
Based on your original post, you’re experiencing issues importing an invalid run. I assume you've tried this - How Do I Manually Upload an Activity I Recorded to Garmin Connect? | Garmin Customer Support
And if you got an error message during that process, you could zip the fit file then attach it to your post
message
How do I zip the file? I tried right clicking on it and can't seem to find that option. I also tried to add it to google drive but it says there is nothing in the file. So I can't even upload the activity file to garmin connect.
This will work - 2025-11-25-15-41-53_fixed.fit
Import the file into Garmin Connect using the "Import Data" option here - https://connect.garmin.com/modern/import-data
