How to see the average of the selection? The zoom window still shows the average values for the entire ride.
It would be nice to see this implemented.
Not exactly what you're looking for but:
- the free site runalyze.com allows you to highlight part of a graph and see the average value (as…
Idk, I can only suggest using strava or runalyze. I know it sucks having to use another service (especially when the data isn't *identical* to Connect since a few things are calculated instead of being…
You can use the Trim function (click the cogwheel icon to see it). The Trim is fully reversible, and you do not even need to save it, and you can…
Strava's clearly the best thought out platform but you don't get much with the free version. Live Garmin segments work reasonable well though.
Runalyze, well it's quirky too, you can select but only for each chart separately, i.e. you can't select a climb on the elevation chart and get the average data for the same selection. Unless there's a setting I'm missing.
Yeah I agree runalyze doesn't have the best UX, although it is more powerful than Connect in some ways. It also has a weird limitation that you need to have a power chart if you want to see certain other metrics when you select a chart region, iirc.
You can always use the laps feature in runalyze to set your own (temporary) custom laps and look at the averages there, although I realize that's not very user-friendly if your goal was just to graphically select a region in the first place.
