I just had my 660 repaired by a place called sharcnet-usa. They put in a new touchscreen, high-capacity battery and fixed my power switch which had been broken for 2 about years.
It looks like they never even opened it. Came back all cleaned up and not a fingerprint on it. Took less than a week to get back. Very pleased.
Bill
I believe that this is a systemic problem, not an isolated event. I have two Nuvi 650 models that have BOTH stopped responding at the same time. This sounds like a recall issue to me. I could understand one failing, but not both.
I updated the firmware, but that didn't help, on either unit.
Garmin's response was unhelpful.
These are the steps I took
From Garmin:I recommend you calibrate the touchscreen on your devices, and then test the unit out.
To calibrate the touchscreen on a nuvi 600 series:
Power the unit On.
From the Where to? / View map screen, touch Settings (wrench icon).
Touch Display.
Touch Recalibrate.
A new screen will display that says Press Dot.
Touch the center of the dot.
Keep touching the center of the dot as it moves around the screen.
When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
Connect your nuvi to your computer with a compatible USB cable.
Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
Open the Garmin folder.
Locate and delete the GUPDATE.GCD file.
Safely disconnect your nuvi from your computer.
Power the nuvi Off.
Power the nuvi on by holding the power button.
Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
Touch the center of the dot as it moves around the screen.
The touchscreen will now be recalibrated and should respond properly. .
Thank you very much!! This work for mine! :)
** Update 27 May 2011 ** Hmm.. I was to quick. My Garmin only work for a few days maximum, just like you all say. I hope Garmin can solve this by a software update, because I really like my Garmin Nav....
