hey madzng,
you can currently change your weight unit of measurement at connect.garmin.com/settings
Suggest submitting your request to Garmin via the Share Ideas | Garmin form. However, if this is deemed a broken feature (rather than a request), then submit a case using the Garmin Support site. Or just…
I want to do the opposite, miles for distance and KG for weight. Really wish I could do this in the app.
Still need this feature (this request is "over 12 years ago")....:
From a product dev perspective this this shouldn't be that hard. Functionality for this sort of inheritance already exists in "Golf Distance Units" (Yards vs Meters).  Is this anywhere on the roadmap?
Bump +1
Still need this feature (this request is "over 7 years ago")....:
I'm trying to do the same thing. Did you find a solution?
Seems there are a number of threads requesting this same feature (mods, could you consolidate for tracking purposes?), some as old as 12 years ago. A quick search:
This shouldn't be hard to do. The "Golf Distance Units' overrides the default measurement units. A similar option should be developed for Strength Workout Units.
Suggest submitting your request to Garmin via the Share Ideas | Garmin form. However, if this is deemed a broken feature (rather than a request), then submit a case using the Garmin Support site. Or just do both.
I already did.
How has Garmin not addressed this issue yet? I don't understand how they can let you do the opposite in Statute UK but not let you select weight units under Metric setting. The functionality is already there they just need to port it over to the metric side as well. It's so frustrating
