Can you help with my file I can't import via garmin connect as it seems that is being related with a planned race. [solved]
This will work - 2024-12-21-11-11-14-fixed.fit
Same issue as others have been reporting with the "phantom" running session.
Fixed using Fit File Repair Tool
Note that if you see the message, "This file has already been uploaded", refer to this post for instructions on how to upload the corrected file and understand why this is happening. - Help Fixing a Corrupt .FIT File
I have the same problem. Could you please help. Thank you so much!2024-12-25-07-50-13.fit
This will work - 2024-12-25-07-50-13-fixed.fit
This will work - 2025-01-04-12-48-15-fixed.fit
Note that if you see the message, 'This file has already been uploaded,' refer to this post for instructions on how to upload the corrected file and understand why this is happening - Help Fixing a Corrupt .FIT File
Fixed using Fit File Repair Tool - F1C91212-fixed.fit
Some suggestions to help minimize the occurrence of corrupt fit files on a Forerunner 35.
Hi would you please help me fix this corrupted file? Thanks!2025-01-18-08-05-05.zip
This will work - 6496816-fixed.zip
