Hi,
Komoot courses show up correctly on my laptop on garmin connect, but does not sync / upload to Edge
Syncs successfully and connects to wifi & BT no issues.
Any ideas why it refuses to update the courses?
It is risky to update an existing course or use the same name as existing courses. It is better to duplicate the course, name it differently and sync it. You can't just change the ending of a name if the name of the course is long since it seems like the name matching isn't done for the full name. It is better to change the beginning of the name to make sure the name is considered to be different.
It can be a good idea to use an incrementing number to make sure the name is unique. I prefix my courses in Strava with "Ride" or "Run" and then add a number and after that a more descriptive name. Example: Ride12-LongSouth110K, Run23-ShortTrail8K
I made changes to the names to make them easier to read on the Edge, the changes were at the end of the names mostly.
What if I deleted all the courses on my laptop by going into the edge memory / course folder and do a bulk delete and then re sync, that would quick and easy to do?
Many thxs for your recommendations :o)
