If you've enabled LiveTrack with "Extend Session Visibility," and it's not past 24 hours ago, you might be able to recover the GPS track using a LiveTrack converter, such as LiveTrack…
What was the distance supposed to be? I see about 2.9 miles or 4.7 km.
Some fit files can be fixed by FIT File Tools, using the section remover without any adjustments. The result can then be uploaded to Garmin Connect Web using the Import Data page. I tested your file, so this…
This is what is showing for files from today. I thought my heart rate data would be the stuff around 18:17 and 18:18. I turned off the watch around 18:25 and didn't turn it on again till plugged into the laptop. I'm not sure what the two _ycle.fit files are but possibly that was me trying to fix it and making a further mistake. Which additional files would you need?
https://drive.google.com/drive/folders/1wA0lH8rGRGTb7TWjecRWC6HD395jSvuL?usp=sharing
This should have the remaining data from today. Thank you!!
So weird, thanks for trying!
Hi I have a fit file seems corrupted, could you please help to take a look? Thank you!
I have a recovered .fit file I need fixed for upload to Garmin drive.google.com/.../view
Thank you very much, I'll check these out. What happened was I stopped for lunch in the middle of my bike ride, but wanted to resume the recording after lunch instead of starting a new one so I kept it paused. At one point I felt my watch buzz at me and looked down to see it saying "discarding activity", there was a return icon but pressing the button next to that did nothing and the activity was lost :-(
Hello, can you help me by checking if this file is repairable pls?
It's a 28,5km run that I made today but I delete it inadvertently.
Thank you in advance
We only succeed to get back 11km, it's even not the half of the run :-(((
I do hope you'll be able to help me !! Many thanks for your time.
