If you've enabled LiveTrack with "Extend Session Visibility," and it's not past 24 hours ago, you might be able to recover the GPS track using a LiveTrack converter, such as LiveTrack…
What was the distance supposed to be? I see about 2.9 miles or 4.7 km.
Some fit files can be fixed by FIT File Tools, using the section remover without any adjustments. The result can then be uploaded to Garmin Connect Web using the Import Data page. I tested your file, so this…
i had the same issue. Was able to found a file that looks lime my activity using recuva, but when I tried to import to Garmin connect it tells me they dont support that type of file. is a .fit file. Any suggestions?
Any suggestions?
Yes. Attach it to this thread. We can take a look to see if it is repairable.
solved
Thank you.
It was on 09/26, started around 8 am, it was about 6.5 hours, 103 miles. The device is a Garmin Edge 820.
solved
Appreciate the help.
I used recuva yesterday 09/28/2021.
No, I havent used my garmin after that.
Yes, I was following a route. And that is one of the reason the issued happen. I went to delete the course in the device and for some reason it also deleted the activity.
this an activity from the day before using the same sensors
