Corrupt fit-file? How to fix?
Hi there!
My device is syncing, but my latest activity does not show up in GC. Manual upload to the activity-list stucks without error message.
What app do I have to use to open file? Any ideas to get this fixed are welcome! :-D
    Hey kiwimtnbkr can you fix this .fit file? If you can it would be appreciated!
    Rhandsome - give this file a try.
    cheers
    Mike
    Hi kiwimtnbkr can you please try and fix my .fit file. Would really appreciate it if you could.
    Hi Mike, Would you be able to fix this corrupt file too? Would be much appreciated! Thanks. Fred
    kiwimtnbkr thank you!
    Hey Mike, just realised that people seem to mention your account name so doing that here just in case. By no means a chase!@kiwimtnbkr
    Boonzi - give this file a try.
    cheers
    Mike
    FGB2018 - give this file a try.
    cheers
    Mike
    kiwimtnbkr Thank you
  • Hi All,
    Not sure if I'm experiencing the same (only recently) file corruptions, would appreciate if anyone who's had similar experience shed some light if possible?
    I usually split my running session to multiple activities recorded separately, usually with a warm-up then followed by the actual workout. I've noticed that last 2 sessions I've done had all the activities showing but the last recorded activity of the session seems to be 'incomplete', i.e. it shows up on (mobile) Connect but I can't view some details, particularly, tabs 2, 3 and 4, only the summary is visible. The tabs remain empty with no data (and no error messages either). They appear fine over the portal though. Only the last one though, the earlier activity/warm-ups shows up as normal.
    I've noticed that changes in the garmin vo2max was also not reflected. Last 2 runs had changes in my vo2max.
    These activities were sync'd over wi-fi.
    I've tried the following but no luck,
    - uninstall and reinstall the mobile app
    - removed the (same) activities and then manually import the fit file again
    Using a 645M, Samsung Note8 (android9) if that matters. Think it's a corrupted file or something else?
    Never had this problem until this week.
