guys there is now a solution in connect.garmin.com
simply choose the activity, hit edit (top right corner) and scroll down to trim activity. There is a scroll bar that you use to trim beginning and end…
I don't understand why it isn't available on every activity type?!?
Hard to tell, but you can trim an activity of any type easily - change the type temporarily to Run or Cycling, trim it, and then…
Very useful and thanks for sharing!
If you edit the time, it will automatically cut off all the other bits so if you know your final triathlon time then you can just enter that (or keep removing bits of time until you get to the point where you peak drops off on say your distance etc.). It only works with editing time, you cannot cut by distance or by steps for example... just the time you want it to stop or start... this can be found by going into your activity in the connect IQ app on your phone, then 3 dots top right, Edit Activity (do not edit your activity here as it is just a number) but there is a Trim Activity button under your Time and Distance . Click on the Trim Activity and you will get your total time, trim start, trim end and a graph to help you find a point you want to trim (though you cannot use the graph but just take the time from it and enter it). Once done, hit save and it will trim off the distance and other stats after the time you state. Hope this helps!
I recorded a triathlon and just forgot to hit stop at the end
Trim is not available at Multisport activities. You would have to export each of the disciplines separately (as Original), delete the multisport activity, then import the individual FIT files for all three disciplines, and then you could trim the one you need. You could not pack it back to a multi-sport activity, though.
I guess it doesn't work when it's captured as a triathlon. When I go online it's not there and when I go into the app it's not there. I tried changing the time to the stop time that it should be and nothing else updated, not even the distance. So I updated the distance too but the map stayed the same as well. I got on the chat window with a support person and said that trim feature is not available for triathlon. Except when I check the list of what it's not available on triathlon isn't on that list. maybe they assumed when they did the code that the individual events would link to the edit tool when you pulled them up individually and just forgot to link that edit code correctly in the code. Seems like it'd be easy to make that adjustment possible.
