My new personal records are not updated in Garmin Connect. Anyone know how I can force this.
Tnx
…my FR630 recorder 9,91 with 41:50. Isn't a closely match?The FR630 is a device model that can detect one or more personal records within a timed activity upon your completing and saving it (before the activity record ever gets uploaded to Garmin Connect), and then tell Garmin Connect about the new PR(s) without relying on GC to do any distance matching. However, unlike in GC, you must complete at least the full 10.0km for the FR630 to recognise a 10K PR; even 9.99km won't do.
Hey, you're right! I did the same. I was able to edit the name, event type, gear and notes without losing the PR. Then, just as you did, I changed the activity type from "running" to "street running" and the record disappeared. Thanks for trouble shooting.
Once you have lost the PR by changing the Activity Type i.e. Running to Street Running, do you know of any way to the PR back?
OK found the solution to my own question. To restore the PR
1. In the activity, under the cog icon, Export Original
2. Delete activity
3. Re-Import the activity you just exported via the "+" symbol at the top right.
4. Go to badges and accept the PR.
Confirming Trouble Source: Activity Type
It is possible to set a recordas described above in Garmin Connect.
If the activity distance doesn't correspond to the record's distance, the activity's time is wrongly assigned to the record distance. Then, the record time can be corrected manually in Garmin Connect. The time can be derived from the activity's data, i.e. auto-laps.
Nevertheless, I agree that this is very annoying and should be fixed by Garmin soon.
