Good morning,
I want to preface this post by saying that I’ve read through the forum and older posts and seen many of the same issues, however, many of those are very old (3-6 years) and I was wondering if anything has changed. I also haven’t seen any posts regarding my watch (Garmin Instinct Solar 1st gen). That said, here’s my issue.
My “active calories” from activities I created or took part in are not adding up correctly when my watch saves the data and syncs with Garmin Connect (iOS and web). For example…
This morning I did two workouts. The first was a strength training workout in which I burned 381 ACTIVE calories (not resting or total). I then did a quick ab workout in which I burned 121 ACTIVE calories. Simple math says that upon concluding those two workouts I should have a minimum of 502 Active calories. However, when I check the Connect app on my iPhone, while the individual workout reports show the above active calories burned, when I look at my daily report it says that I’ve only burned 328 active calories. That’s 174 calories less than what my watch and the activities reported.
I understand how active calories vs resting calories work and how those two metrics together make up your total calories. I’m just referring to the active calories not adding up in this case. Has anybody had any issues with this and are there any solutions?
Thank you for your time and patience
